Old 06-13-2012, 06:42   #1 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
n79 phone startup failed
Phone type: RM-348 (Nokia N79)
SW version: V ICPR72_09w18.4 14-10-09 RM-348 (c) Nokia
ApeCoreSw: 32.001
Imei plain: 356387xxxxxxxxxx
Product code: 0576100
Battery voltage: 4357 mV, current: 2 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK invalid!
Imei net: 356387xxxxxxxxx
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Latest software release for Nokia N79 is 31.002
before flashing it is hang on nokia nokia logo
then i've try to flash the mobile it is same fault.
then backup and erase file with this one
flashed with mobileex_NAND_uni_erase_BB5.XSR1.fpsx file
backup resored
now the phone is startup failed
Old 06-13-2012, 08:59   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Follow this Link: http://forum.gsmhosting.com/vbb/f550...oblem-1485570/ & will solve your problem.
BR,
Old 06-13-2012, 11:39   #3 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
i've write all backups also . but same complaint
after write the backup rpl here is the log
Imei: 35638702200095
Restoring RF/BB DATA from backup ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 10E0011687700052463663D7E0D6D5F5467E1F84
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.50.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.50.0 revision: 2.0 size: 0x8B45D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: B2075F4B793BB9017C8C0097C783C543F2A6A303
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...error 0x0
Updating PROD ...OK
Updating BT ...OK
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C085DA79
Using device: HTI, FW ver: 00.50, SN: 00012A42
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Prog.status for Asic CMT ...
NAND: OK
Updating PRODUCTCODE (0576100)... error 0x0
Updating PSN (CEK514781)... OK
Updating HWID (6000)... error 0x0
Updating SIMLOCK ...OK
Updating SUPERDONGLE_KEY ...error 0x0
Updating CMLA_KEY ...OK
Updating WMDRM_PD ...OK
Imei plain: 35638702200095-5
Product code: 0568365
Battery voltage: 4506 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
Imei net: 356387022000955
Counter: 0/3, 0/10
after bus check log here is
ApeCoreSw: 32.001
Battery voltage: 4509 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
e2230l repair imei failed. [Answered] reimon23 Activation Software Support (HTC, BLACKBERRY, ALCATEL, LG/ZTE, SAGEM/SE) 12 10-25-2012 08:11
6120c sd problem, now security test failed help trio1 Advance-Box 8 06-13-2012 13:30
AnyCall w720 Unlock failed.. ticksjarub VygisToolbox 9 06-13-2012 12:49
i want Mu.phone M6000 Flash file (ANSWERED) gsmshankarb Chinaking Box 2 06-12-2012 13:22
chiana phone needed halp raziqbbr Chinese Models & Cloned Phones 0 06-12-2012 11:43
Page generated in 0.19867 seconds with 9 queries
