03-23-2010, 09:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | n95 8g rm-320 security fail need help :) Code: Product: V 06wk41v59 22-05-08 RM-320 (c) Nokia Using cached productData[18900002777300521D47EFD033AEA6763892C8D1] ... Calculating SIMLOCK using security server ... Completed in 1.312 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_359542018200962_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 359542018200962 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Product: V 06wk41v59 22-05-08 RM-320 (c) Nokia Using cached productData[18900002777300521D47EFD033AEA6763892C8D1] ... Calculating SUPERDONGLE using security server ... Completed in 4.156 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_359542018200962_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK info Code: Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v59 22-05-08 RM-320 (c) Nokia Imei plain: 359542018200xx-x Product Code: 0566134 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359542018200xxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V 06wk41v59 22-05-08 RM-320 (c) Nokia Using cached productData[18900002777300521D47EFD033AEA6763892C8D1] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.218 s check various Code: Reading RAP NPC (0x1B8 bytes) Original Product Code: 0566134 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! Reading RAP CCC (0x160 bytes) Product Code: 0566134 CCC seems to be valid Reading RAP HWC (0xD4 bytes) Product Code: 0566134 HWC seems to be valid thx u for help |
03-23-2010, 10:19 | #2 (permalink) |
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | write rpl no NPC get error like this NPC verified Ok. Updating CMT CCC ...OK Updating CMT HWC ...OK Updating APE HWC ...failed, Result: 0600000000317200 Certificate programmed successfully ! |
03-23-2010, 10:28 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | post here we will help you http://forum.gsmhosting.com/vbb/f550...l-here-945700/ |
N95 8G Rm-320 no light lcd help? | haigoshi | Nokia Base Band 5 ( BB-5 ) | 5 | 08-28-2010 01:06 |
N95 8G RM-320 [ Failed to extract the content ] | MaikonPhone | HWK | 2 | 01-10-2010 19:51 |
n95-8g rm 320 chinese ppm needed | owoeye | Nokia Base Band 5 ( BB-5 ) | 1 | 06-13-2009 08:36 |
N95 8G RM-320 downgrade with MT failed....help me... | atlan | Nokia Base Band 5 ( BB-5 ) | 1 | 01-24-2009 08:03 |
Masters... i need pin out for N95 8g RM-320 | -=whitezaNder=- | Chinese Models & Cloned Phones | 3 | 12-03-2008 04:08 |
