Old 02-24-2010, 14:43   #1 (permalink)
Member: 573283
Thanks Meter: 5
New problem comes after rehabilitate of SD and SL=0000000
New problem comes after rehabilitate of SD and SL=0000000, refer to https://forum.gsmhosting.com/vbb/f550/help-how-fix-phone-sd-damaged-sl-0000000-a-935220/
Now the phone can't be authorized by local SX4 card on original phoenix sofeware (Nokia Care center) , so can't be performed testing of singal loop, such as TX, RX, PLL etc., and no help to evaluate source of singal problem when has the singal problem.
This is confused for me. Why??? Who can explain?
Old 02-24-2010, 15:24   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
cos this SUPERDONGLE repair use "unique" service to repair
not from NOKIA CALCULATION SERVER,
if u want use , nokia equipment tools ( like SX-4 )
must repair with original RPL from NOKIA CALCULATION SERVER
about signal testing,
how about use SELFTEST diagnose result.
isn't help ?
br,
Old 02-24-2010, 15:55   #3 (permalink)
Member: 573283
Thanks Meter: 5
isn't help ?
br,
Maybe, but i will lose the signal turning function of Nokia Phoenix sofeware, because the phone can't be authorized by local nokia's SX-4 then can't active the signal turning function of Nokia Phoenix sofeware.
Old 02-24-2010, 17:17   #4 (permalink)
Member: 729543
Thanks Meter: 4
Imei Empty..
5310 Xpress
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101013000
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1BD00110E0850254AFEF4B3BF7369616D86B4D1C
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
Original Imei: Empty
Original Product code: Empty
Phone not responding !
How repair that.. mising RPL i dont
Old 02-24-2010, 17:22   #5 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Thanks Meter: 94
Maybe there's no sw present in phone, try to write/flash the phone. Or phone not completely booted. Hope not damaged IMEI.
Old 02-24-2010, 17:32   #6 (permalink)
bireun's Avatar
Member: 796141
Thanks Meter: 25
@Smartmio
no signal after repair SD if software problem
try this method
http://forum.gsmhosting.com/vbb/show...78#post5477778
Old 02-24-2010, 17:41   #7 (permalink)
DON THE KILLER's Avatar
Member: 619319
Sonork: 100.1590240
Thanks Meter: 76
is this working....................................
Help,how to fix the phone with SD damaged and SL=0000000? Smartmio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-24-2010 11:26
5130c after repair sd erRor and sl crrupted ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-03-2010 13:55
In new Beta Test software of mxkey can we repair damage sd and repair simlocks?? armanhosting MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 01-16-2010 06:48
my gui wont open after update of shell and tools snakebreeder Z3X-Team Products 1 12-15-2009 11:34
BB5 king after unlocked comes new problems! tuhingr BB5KING 15 12-20-2008 16:43
Page generated in 0.19372 seconds with 9 queries
