02-24-2010, 10:18 | #1 (permalink) |
Junior Member Join Date: Aug 2007
Member: 573283 Status: Offline Thanks Meter: 5 | Help,how to fix the phone with SD damaged and SL=0000000? Phone Type: RM-243 (Nokia 6120) SW Version: V 07.10 15-07-09 RM-243 (c) Nokia Imei plain: 356***03001834-3 Product Code: 0581707 ApeCoreSw: 07.10 ApeVariant: rofs_version_inforofx_version_info ApeTest: rm243_ENO_A_2009wk15v0.100 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! Bros, please help, how to do, any process step?? Thanks! |
02-24-2010, 10:22 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | reapir simpock repair sd and write pm 1 and 309 field with super sd |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
02-24-2010, 10:29 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
see this guide my friend you can in minets it (bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik br naveed butt | |
02-24-2010, 10:56 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | i thinks this clear step Code: Just an information. starting from mobileEx 3.3 Rev1.5, now repair SL and SD is done by single button "repair SD". So if you want to repair SL, the whole procedure is as simple as: 1. backup RPL(just in case). 2. erase EEPROM. 3. Repair SD 4. Full Factory 5. SUPER SD Auth + Write PM1,309 if these steps still not fix the phone, please do BB5 Cert Validation + repair procedure as described on previous post above. BR ps. be sure that you are always using the latest release nokia module (Option > Nokia Service Tool > Update) [MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx - br, |
The Following User Says Thank You to Andra For This Useful Post: |
how to flash the phone with same product code | preshaust | Cyclonebox | 7 | 02-01-2011 13:44 |
How to repair the phone is SD keyde MX 3110c | ramazan.keskin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-10-2010 13:16 |
how to fix confirguration key with cyclone [Job done with the last update] | bolaji olugbani | Cyclonebox | 3 | 01-05-2010 09:53 |
How to fix the phone with dead USB boot for Z500 | sim1 | QUALCOMM Models (3G) | 3 | 08-29-2005 14:05 |
How To Fix The Cable To Fisio 355 ? I Need Help | sunrise gsm | Redbox | 17 | 01-27-2005 10:41 |
