Old 01-26-2010, 15:39   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
>>> Nokia 2320c-2b (RM-515) Unlocked Successfully <<<
Nokia 2320c-2b (RM-515) unlocked successfully after lot of tries and R&D.. Model is presently not supported for unlocking with MX Key..
Even if u flash to RM-514 firmware, unlock is not supported..
Here is the original simlock info >>>
Phone Type: RM-515 (Nokia 2320c-2b)
SW Version: V 06.88 06-07-09 RM-515 (c) Nokia
Imei plain: 011975003xxxxx
Imei OTP: 011975003xxxxx
Product Code: 0579480
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: NCR
Language Pack:
- not available.
"C:\Program Files\Nokia\Phoenix\Products\RM-515" folder created.
Imei net: 011975003xxxxx
Version: SIMLOCK SERVER
Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A.
Counter: 0/3, 0/10
CONFIG_DATA: 3101700000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.LOCKED (MCC+MNC): 310150
BLOCK 2: 1.LOCKED (MCC+MNC): 310170
BLOCK 3: 1.LOCKED (MCC+MNC): 311180
BLOCK 4: 1.LOCKED (MCC+MNC): 310410
BLOCK 5: 1.LOCKED (MCC+MNC): 310980
Here is the trick, how I managed to unlock it >>>>
Flashed it with Nokia 2330c (RM-512) firmware sw ver 6.75 ..
Then proceeded for unlock operation and got the handset unlocked smoothly..
After that just wrote the pm attached for network and then harware conversion..
Handset unlocked and now showing both 900/1800 MHz networks..
Here is the log >>>
Counter: 0/3, 0/10
PhoneType:RM-512
SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia
MCU file: rm512__06.75.mcusw
Trying to find patch position ...OK
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 0049B319:3B8ADA60
Area [01000000-0101FFFF] erased in 0.890 s
Area [01220000-0123FFFF] erased in 0.844 s
Area [01440000-0145FFFF] erased in 0.922 s
Area [014C0000-014DFFFF] erased in 0.781 s
Area [01CE0000-01CFFFFF] erased in 0.031 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 1 min 16.828 s
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following 17 Users Say Thank You to zeel_zeel For This Useful Post:
Old 01-27-2010, 20:54   #2 (permalink)
Member: 207455
Thanks Meter: 35
didnt work for me
Invalid File Header
Flashing terminated with error(s) in 21.282 s
RX Buffer:
The Following User Says Thank You to bowei For This Useful Post:
Old 03-15-2010, 20:29   #3 (permalink)
tigran80's Avatar
Member: 195651
Thanks Meter: 133
Originally Posted by bowei View Post
didnt work for me
Invalid File Header
RX Buffer:
try the procedure many times and get result, or flash with MT-Box and then unlock with MX for free.
Old 03-24-2010, 19:31   #4 (permalink)
daneriscelular1's Avatar
Member: 788037
Thanks Meter: 45
Thumbs up Nokia 2320c-2b Unlocked 10000% tested
here is my log
Counter: 0/3, 0/10
PhoneType:RM-512
UEM ID: 00DF399C:3B8ADA60
Area [01000000-0101FFFF] erased in 0.982 s
Area [01220000-0123FFFF] erased in 0.811 s
Area [01440000-0145FFFF] erased in 0.921 s
Area [014C0000-014DFFFF] erased in 0.851 s
Area [01CE0000-01CFFFFF] erased in 0.130 s
Programming ...
Completed in 1 min 41.416 s
Imei net: 0119750041******
Counter: 0/3, 0/10
The Following User Says Thank You to daneriscelular1 For This Useful Post:
Old 04-06-2010, 13:29   #5 (permalink)
Member: 186317
Thanks Meter: 3
GOOD WORK MAN,THNKS ALOT I DO AS U SAID AND IT UNLOCK FINE.BUT MY PROBLEM IS DAT DE NOKIA 2320C-2b IS O1 FROM US,SO IS NOT SEEING SERVICE IN MY COUNTRY.NIGERIA
Old 04-06-2010, 13:36   #6 (permalink)
Member: 186317
Thanks Meter: 3
HOW TO UNLOCK 2320C-2b successfully 100% unlock
ANYBODY DAT SAID IS NOT WORKING.OK FLASH WITH JAF USE rm-512 V08.20 TO FLASH IT.AFTER FLASHING IT NOW USE MXKEY TO UNLOCK IT AND PICK DE 08.20 MCU FILE.PHONE WORK FINE 100% GUARANTEE.
Old 04-30-2010, 07:29   #7 (permalink)
Member: 1250836
how about the camera its not working ..
camera on stand by????
Old 06-24-2010, 14:55   #8 (permalink)
tchinidor's Avatar
Member: 422574
Thanks Meter: 85
wts this pinout or flash file ?????
Old 06-24-2010, 22:02   #9 (permalink)
tchinidor's Avatar
Member: 422574
Thanks Meter: 85
wawwww
100% work
flash it w rm-512
unlock w mx
good PM file
and try this
The Following 5 Users Say Thank You to tchinidor For This Useful Post:
Old 06-25-2010, 04:05   #10 (permalink)
AlfskieCoder's Avatar
Member: 1225453
Thanks Meter: 501
good post and idea you made sir....i'll try it 100% tested
Old 10-18-2010, 22:18   #11 (permalink)
tchinidor's Avatar
Member: 422574
Thanks Meter: 85
100% working tested by me
the picture is not the phone but the principle is the same
have a nice day
riad
Old 10-19-2010, 02:00   #12 (permalink)
Member: 497374
Sonork: 1587252:AZAD
Thanks Meter: 93
thanks brother for ur nice update information
Old 02-17-2011, 06:22   #13 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 788
http://forum.gsmhosting.com/vbb/f148...lution-993648/
Old 03-09-2011, 23:56   #14 (permalink)
Member: 372163
Thanks Meter: 57
Ppm Id: NCR
Language Pack:
- not available.
Counter: 0/3, 0/10
Here is the log >>>
Counter: 0/3, 0/10
PhoneType:RM-512
Programming ...
Counter: 0/3, 0/10
is a nice share man,im yet to giv it a try nd post results,stay blessed
Old 03-11-2011, 15:04   #15 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
Originally Posted by tchinidor View Post
wawwww
100% work
flash it w rm-512
unlock w mx
good PM file
and try this
hmmmmmmm goood...................
Nokia 2720a-2b RM-520 Unlock curtisbcm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 09-09-2010 02:57
NOKIA 2680s-2b RM-393 UNLOCK? mint centre Universalbox 8 06-28-2010 15:55
nokia 1680c-2b rm-490 unlock ok the_yankee Universalbox 1 02-05-2010 19:47
NK 2320c -2b RM-515 not supported nicacel Universalbox 7 12-16-2009 21:12
Nokia 5610d-2b rm-359 unlocked successfully UNIQUEM MT-BOX 0 03-17-2009 13:48
Page generated in 0.24871 seconds with 10 queries
