Old 02-15-2010, 06:39   #1 (permalink)
jodhpur_raj's Avatar
Member: 737954
Sonork: Mobile
Thanks Meter: 107
Nokia 7210c SECURITY_TEST failed!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15A0020A7C247D56AB33650D00D3B7ED1D260433
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 351***********
Original Product code: 0572571
Bluetooth ID: 00247CC9121C
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 04.86 08-08-08 RM-436 (c) Nokia
Imei plain: 351***********
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 351962039422916
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
how solu this problem
The Following 3 Users Say Thank You to jodhpur_raj For This Useful Post:
Old 02-15-2010, 06:45   #2 (permalink)
Cheater -Don't Deal with him-
Member: 975047
Thanks Meter: 330
write good pm with sx4 auth
The Following User Says Thank You to GsmDiamond For This Useful Post:
Old 02-15-2010, 06:47   #3 (permalink)
Member: 737954
Sonork: Mobile
Thanks Meter: 107
My Problem solu................ I Go to service-> IMEI & Security->IMEI rebuild->Repair SD
and Go to service->PM->SUPER SD Auth
Write Full Modified PM........
The Following 4 Users Say Thank You to jodhpur_raj For This Useful Post:
Old 02-15-2010, 06:57   #4 (permalink)
Member: 737954
Sonork: Mobile
Thanks Meter: 107
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 351************
Product Code: 0566806
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351*************
Counter: 0/3, 0/10
Total time to process is 10 min 44.469 s
The Following User Says Thank You to jodhpur_raj For This Useful Post:
Old 02-15-2010, 06:58   #5 (permalink)
AL879's Avatar
Member: 588777
Thanks Meter: 28
hehe already ok,anyway congrats bro
can you share the procedure how can you solved
just only for reference........thanks
Old 02-15-2010, 07:00   #6 (permalink)
Member: 975047
Thanks Meter: 330
Originally Posted by AL879 View Post
im tested 100% this procedure,you try this one
1 SERVICE,IMEI & security,IMEI rebuild AND click Recover CERT,after finished
2 SERVICE,PM,PM Auth,load from file,write and SUPER SD auth,thats all........
i hope it help with you.........
u hav'nt see and read his post?
he have solve his problem
Old 02-15-2010, 08:10   #7 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
http://forum.gsmhosting.com/vbb/showthread.php?t=926798
Old 02-16-2010, 06:59   #8 (permalink)
Member: 737954
Sonork: Mobile
Thanks Meter: 107
Old 02-16-2010, 07:00   #9 (permalink)
Member: 737954
Sonork: Mobile
Thanks Meter: 107
Old 02-16-2010, 07:40   #10 (permalink)
Member: 1019058
Thanks Meter: 20
http://www.mediafire.com/?m4glo4llolz try he vedeo
Old 02-16-2010, 07:49   #11 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
i have 7210c cs problem i did sd repair cs problem solved but it is become new problem created now camera standby mode
how solve this problem?
The Following User Says Thank You to umarmsn For This Useful Post:
Old 02-16-2010, 07:57   #12 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Write full pm without (field 120 n 308)with super sd.
Old 02-16-2010, 08:04   #13 (permalink)
Member: 1224463
Sonork: Kafi_ctg
Thanks Meter: 26
U can repair it with mxkey..
Old 02-16-2010, 08:06   #14 (permalink)
Registered User
Member: 751390
Thanks Meter: 18
Old 02-16-2010, 08:11   #15 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
erase flash with bb5 erase file and repeat procedure
Nokia 7210c SECURITY_TEST failed! .:KRISHNA:..:MOBILE:. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 06-07-2010 14:05
plz help me mr manole . still problem with 7210c SECURITY_TEST failed! jagdish puri MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 02-09-2010 13:18
Nokia e65 SECURITY_TEST failed![SOLVED] sebY7676 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 02-07-2010 20:52
after sd repair 7210c SECURITY_TEST failed! snkhan70 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-03-2010 16:06
nokia 3110 SECURITY_TEST failed CellWorm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 12-04-2009 06:48
Page generated in 0.22011 seconds with 9 queries
