01-30-2010, 06:13 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | pls help 5310 contact service[SOLVED] Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 21D000149FFB8956E88B6A43E882BA221FCFE665 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Original Imei: 35421803620467 Original Product code: 0574684 Bluetooth ID: 0025D0819EFB Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 10.10 23-03-09 RM-303 (c) Nokia Imei plain: 35421803620467-5 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354218036204675 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF self test logs Phone Type: RM-303 SW version: V 10.10 23-03-09 RM-303 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y !FAILED(01) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N !NOT EXECUTED(03) 93 SECURITY N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 32 AMB_LIGHT_SENSOR N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) thanks...... |
01-30-2010, 06:18 | #2 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | it's not possible anyway..i tried many time having many procedure the contact service remain same.. |
The Following User Says Thank You to xim360 For This Useful Post: |
01-30-2010, 06:19 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: KERALA,INDIA Age: 38
Member: 597241 Status: Offline Sonork: 100.1575009 Thanks Meter: 85 | pls write good pm after pm auth will sort out ur problem |
The Following User Says Thank You to vijeeshkannur For This Useful Post: |
01-30-2010, 06:25 | #4 (permalink) |
Member: 507861 Status: Offline Thanks Meter: 69 | i allready try to sx4 auth and write the good pm but no luck still cs...but ill try again at the second time as you wiss...ill post result after i do sx4 auth and write another pm...thanks mate |
01-30-2010, 19:26 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 3 times success or no ? what last condition here ? please post log when u try sx-4 and write PM here. br, |
The Following User Says Thank You to Andra For This Useful Post: |
01-31-2010, 00:15 | #9 (permalink) |
Freak Poster Join Date: Oct 2008 Location: philippines Age: 55
Member: 883572 Status: Offline Thanks Meter: 63 | try another pm n write field 1 n 309 with sx4 authorize. u probaBLY BEEN USING SAME BAD PM. TRY ANOTHER PM |
The Following User Says Thank You to ferdie1969 For This Useful Post: |
01-31-2010, 02:19 | #10 (permalink) |
Member: 507861 Status: Offline Thanks Meter: 69 | here is the logs after sx auth and writing pm...still contact service... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 21D000149FFB8956E88B6A43E882BA221FCFE665 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Original Imei: 35421803620467 Original Product code: 0574684 Bluetooth ID: 0025D0819EFB Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 10.10 23-03-09 RM-303 (c) Nokia Imei plain: 35421803620467-5 Product Code: 0547371 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354218036204675 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F Code: Connecting to server ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 124.6.181.214 SUPERDONGLE auth succeeded! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 1, size 800 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 8 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 24 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 2 bytes written. - Key: 65, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 16 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 1, size 2 bytes written. - Key: 3, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 19, size 8 bytes written. - Key: 25, size 2 bytes written. - Key: 37, size 4 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 48, size 4 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 58, size 2 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 123, size 8 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 133, size 2 bytes written. - Key: 135, size 2 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. Section: 24 Section: 31 - Key: 4, size 18 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 44 Section: 49 - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 59 - Key: 0, size 84 bytes written. - Key: 1, size 137 bytes written. - Key: 2, size 99 bytes written. - Key: 3, size 121 bytes written. - Key: 4, size 85 bytes written. - Key: 5, size 50 bytes written. - Key: 6, size 93 bytes written. Section: 60 - Key: 0, size 80 bytes written. - Key: 1, size 42 bytes written. - Key: 2, size 41 bytes written. - Key: 3, size 55 bytes written. Section: 61 - Key: 0, size 92 bytes written. - Key: 1, size 107 bytes written. - Key: 2, size 58 bytes written. - Key: 3, size 95 bytes written. - Key: 4, size 33 bytes written. Section: 66 - Key: 0, size 2050 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 57, size 8 bytes written. - Key: 58, size 8 bytes written. - Key: 59, size 8 bytes written. - Key: 60, size 8 bytes written. - Key: 61, size 8 bytes written. - Key: 63, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 75, size 8 bytes written. - Key: 76, size 8 bytes written. - Key: 78, size 6144 bytes written. - Key: 79, size 300 bytes written. - Key: 80, size 60 bytes written. - Key: 85, size 8 bytes written. - Key: 86, size 3 bytes written. - Key: 87, size 3 bytes written. - Key: 88, size 3 bytes written. - Key: 89, size 3 bytes written. - Key: 91, size 3 bytes written. - Key: 92, size 3 bytes written. - Key: 93, size 3 bytes written. - Key: 94, size 3 bytes written. - Key: 95, size 3 bytes written. - Key: 96, size 3 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 280 bytes written. - Key: 99, size 300 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 4 bytes written. - Key: 102, size 280 bytes written. - Key: 103, size 6 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 109, size 441 bytes written. - Key: 110, size 441 bytes written. - Key: 114, size 120 bytes written. - Key: 116, size 30 bytes written. - Key: 118, size 33 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 24, size 596 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 4, size 9 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 16, size 40 bytes written. - 120 skipped Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 202 Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 232 - Key: 0, size 20 bytes written. Section: 238 Section: 250 - Key: 1, size 2076 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 692 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 304 - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. - Key: 19, size 148 bytes written. - Key: 20, size 148 bytes written. - Key: 21, size 148 bytes written. - Key: 22, size 148 bytes written. - Key: 23, size 148 bytes written. - Key: 24, size 148 bytes written. - Key: 25, size 148 bytes written. - Key: 26, size 148 bytes written. - Key: 27, size 148 bytes written. - Key: 28, size 148 bytes written. - Key: 29, size 148 bytes written. - Key: 30, size 148 bytes written. - Key: 31, size 148 bytes written. - Key: 32, size 148 bytes written. - Key: 33, size 148 bytes written. - Key: 34, size 148 bytes written. - Key: 35, size 148 bytes written. - Key: 36, size 148 bytes written. - Key: 37, size 148 bytes written. - Key: 38, size 148 bytes written. Section: 322 Section: 325 - Key: 0, size 22 bytes written. Section: 334 Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4284 bytes written. Section: 354 - Key: 0, size 3 bytes written. Section: 355 - Key: 1, size 2028 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 362 - Key: 1, size 120 bytes written. Section: 364 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 365 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Completed in 59.396 s Last edited by Andra; 01-31-2010 at 03:21. Reason: add tag code |
pls help 5220 contact service | soukot.bd | Nokia Base Band 5 ( BB-5 ) | 3 | 02-09-2010 09:35 |
Pls Help 7210c CONTACT SERVICE | mondal38 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-20-2010 14:46 |
nokia 5310 contact service pls help | 00aa | Universalbox | 19 | 03-30-2009 21:08 |
pls help 6270 contact service | markrhi | Nokia Base Band 5 ( BB-5 ) | 3 | 09-02-2007 09:12 |
pls help with contact service 2100 | alexander_bg | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 07-24-2003 04:23 |
