05-15-2003, 07:28 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | @alexander_bg Hello Friend, Firstly Flash your phone with any other Good 2100 flash file and then ??? your phone will Display (Contact Service) Use NokiaTool 1.8 By Rolis and use the following options :- Use Mbus cable same for 8210 and keep the phone in ON mode while you run this software.... 1.) Clear SpLocks 2.) Change Imei (Original From the Back) 3.) Update Faid That's all Regards, Tanvir !!! |
06-12-2003, 16:48 | #8 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | listen man use nokia tools by rolis ver 1.9 and use MBUS to read the phone(just read) there u can see the Cobba ID if this id is anything like 00 00 00 00 then it is hardware related CS (probably cobba is dry soldered or faulty) but if it is okay then flash your phone again from any file readed from a working nokia 2100 phone |
06-12-2003, 21:27 | #9 (permalink) |
Freak Poster Join Date: Mar 2002 Location: BULGARIA Age: 48
Member: 10423 Status: Offline Thanks Meter: 15 | @dsimka ok my friend i will send to you but you cant mend it because phone have HW problem. It give nothing about ROM version. all other 2100 give ROM 6.... @syed thx for your reply i already do it but problem is not in cobba.... so if you have other ideas i m ready to try it regards sasho |
07-08-2003, 22:06 | #12 (permalink) |
Junior Member Join Date: Nov 2001 Age: 46
Member: 7320 Status: Offline Thanks Meter: 0 | hi man first you must use eprom tools v3.1 open the program connect the phone m-bus cable on com1 than click the TEST button on the soft than send answer of the program to forum |
pls help 5220 contact service | soukot.bd | Nokia Base Band 5 ( BB-5 ) | 3 | 02-09-2010 09:35 |
pls help 5310 contact service[SOLVED] | ELOY1024 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 02-01-2010 04:09 |
Pls Help 7210c CONTACT SERVICE | mondal38 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-20-2010 14:46 |
pls help 6270 contact service | markrhi | Nokia Base Band 5 ( BB-5 ) | 3 | 09-02-2007 09:12 |
help with contact service | ryumahon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-27-2001 13:12 |
