pls help with contact service 2100 hi. pls help for repair contact service - nokia 2100. |
@alexander_bg Hello Friend, Firstly Flash your phone with any other Good 2100 flash file and then ??? your phone will Display (Contact Service) Use NokiaTool 1.8 By Rolis and use the following options :- Use Mbus cable same for 8210 and keep the phone in ON mode while you run this software.... 1.) Clear SpLocks 2.) Change Imei (Original From the Back) 3.) Update Faid That's all Regards, Tanvir !!! |
@Tanvir thx about reply but this is not help me.... i arelady made all this steps but not luck... phone still is in contact service regards sasho |
try this change eeprom bin and change imei with original, update faid... |
Just use rolis tools after flashing.100% works |
Sorry.nokia tools not rolis,surely 100% works.tried b4 |
finaly use Bulgarian POST service and send it to me :-) |
listen man use nokia tools by rolis ver 1.9 and use MBUS to read the phone(just read) there u can see the Cobba ID if this id is anything like 00 00 00 00 then it is hardware related CS (probably cobba is dry soldered or faulty) but if it is okay then flash your phone again from any file readed from a working nokia 2100 phone |
@dsimka ok my friend :) i will send to you but you cant mend it because phone have HW problem. It give nothing about ROM version. all other 2100 give ROM 6.... @syed thx for your reply i already do it but problem is not in cobba.... so if you have other ideas i m ready to try it :) regards sasho |
Hardverski ili softverski kontakt servis? |
plz use only english laguage for make post. thanks for your co-operation;) |
hi man first you must use eprom tools v3.1 open the program connect the phone m-bus cable on com1 than click the TEST button on the soft than send answer of the program to forum |
2100 c.s Have solved the problem.I use nk tools.Any way thanks for your reply |
And finaly 2 - give to Sid - hi will come to me today and tomorow will take back to you! Don't worry about DSP... |
@debeliamark thx :) problem solowed !!! i have put new flash chip inside and after reflash all is ok regards sasho |
