Old 04-27-2010, 08:45   #1 (permalink)
Member: 10125
Thanks Meter: 287
Security TEST FAIL!!!!!!!!!!!!!
Hi All,
Any clue to solve this!!!!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010)
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: BCC51474D2E5EA4C99F94BD10E439CF197657D5D
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0FF000119A7600584AD390FCAD9D86EC50A2DFB9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 1.37.1 revision: 0.0 size: 0x3B80
 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035  - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAPIDOv11_algo.fg [XSR 1.5]  version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
 SecondaryBoot: omap2420_m1_2nd.fg [BB5]  version: 1.41.0 revision: 0.0 size: 0x7C00
 Supported APE Ids: 24200703, 24200704, 24200705, 24200706
FlashID0: 00EC 0040  - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
 Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG]  version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
Original Imei: 35XXXXXXXXXXX
Original Product code: 0550349
Bluetooth ID: 001E3A27DAB7
WLAN ID: 001E3A18986B
Phone Type: RM-159 (Nokia N95)
SW Version: V 06wk41v59.1 02-06-08 RM-159 (c) Nokia
Imei plain: 35XXXXXXXXXXX
Product Code: 0550349
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 35XXXXXXXXXXX
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
When try to repair with writting PM, permanately got this:-
""Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Product: V 06wk41v59.1 02-06-08 RM-159 (c) Nokia
Using cached productData[0FF000119A7600584AD390FCAD9D86EC50A2DFB9] ...
Authenticating to SUPERDONGLE using security server ...
ERROR: something went wrong while receiving packet from server (c:1)!
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.212.XXX.XXX
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 04-27-2010, 08:49   #2 (permalink)
Member: 507861
Thanks Meter: 69
try sd repair first then super sd auth and write pm...
Old 04-27-2010, 08:54   #3 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
1.Service > Imei & Security > Imei Rebuild > Repair SD
2.Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
3.Service > PM >load.PM.Super SD Auth.write PM imediately.
Old 04-27-2010, 08:57   #4 (permalink)
babloojaved's Avatar
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
Originally Posted by mmdebili View Post
1.service > imei & security > imei rebuild > repair sd
2.service > imei & security > simlock : Repair simlock > repair splock
3.service > pm >load.pm.super sd auth.write pm imediately.
why you are saying to repair super dongle it is ok
it is server problem
try 2 or 3 times one by one (pm auth or sd auth)
he will be succeed and then write pm
br.
Thanks
Old 04-27-2010, 09:01   #5 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
br.
Thanks
really it will be server problem. you can try letter
Old 04-27-2010, 09:05   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
what is the phone condition before?
it is recommended to use the original SX4 instead of super SD if the phone is "VIRGIN"
Old 04-27-2010, 09:17   #7 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
br.
Thanks
if server working try my solution all will be ok brother
Old 04-27-2010, 13:14   #8 (permalink)
Member: 10125
Thanks Meter: 287
Thanks ALL !!!!!!!!!!!!!
Hi All,
Thanks a lot all for replying. well after hours of trying I got the fone fully working back again (5hrs of burning test till now) but surprisingly even though "SUPERDONGLE_KEY invalid!" as per log
Version from phone: 06wk41v31
Version from file: susd
Rpl backup already exist (C:\mobileEx\3.3\data\backup\BB5_358XXXXXXXXX_BACK.rpl).
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 128.00 KB
APE NAND area [000C0000-000DFFFF]
erased in 0.047 s
Erase completed in 0.156 s
Flash programming ...
Programming completed in 0.062 s
Flashing completed in 10.641 s
SW Version: V 06wk41v31 05-06-07 RM-159 (c) Nokia
Imei plain: 35XXXXXXXXXXXX-7
Language Pack:
- not available.
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35XXXXXXXXXXXX7
Counter: 0/3, 0/10
Total time to process is 21.157 s
My observation is, there is really a problem with the SERVER actually and lot of bug with this new version 1.8fix of MX key.
The step of procedure was as follows: hopefully that could help others members of the forum.
1- Fully erase the fone (removing tick in safe Erase area) using mxkey 1.8fix version
2- Flash win ENO firmware
3- Full flash any firmware version (using mxkey crack version) the 1.8fix got to much bug for flashing randomly you got different kind of error like (APE bootloader not responding and etc.....)
4- Restore IMEI - Recover CERT - Reset All
And my fone is back alive again. for your information have try to repair the "SUPERDONGLE_KEY" but no luck I'm back again with SECURITY_TEST Fail and fone with "start up failure contact the Retailer"
Again Thanks All
Regards
OzCOM
Old 04-27-2010, 13:27   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
try to play a music....
let's see.
Old 04-27-2010, 15:57   #10 (permalink)
Member: 10125
Thanks Meter: 287
let's see.
As I specify the fone is working perfectly up to now (10Hrs burning test) with everything TEST
CALL TEST, BLUETOOTH, MUSIC PLAYER, CAMERA ETC ETC....
Regards
OzCOM
Old 04-27-2010, 16:30   #11 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
Regards
OzCOM
Good News Brother ------------->>>>>>>>>>>>>>>>>>>>>
Security Code dESiRE! Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 05-13-2011 22:17
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-05-2010 09:04
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
SECURITY CODE AWLABA Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 02-22-2000 23:38
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.25531 seconds with 9 queries
