02-03-2010, 15:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | Security test failed after sd repair.. SW Version: V 06.00 28-11-07 RM-198 (c) Nokia. Imei plain: 35************* Product Code: 0546100 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! I TRY SUPER SD AUTH....BUT NO LUCK.. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 06.00 28-11-07 RM-198 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! warning: SD authorized but verify failed ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (86 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (86 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 31 (86 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 0.797 s NOW THE HANDSETS IS ON CONTACT SERVICE. HOW TO SOLVE THIS PROBLEM? |
02-03-2010, 15:50 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | |
02-03-2010, 16:04 | #4 (permalink) | |
Freak Poster Join Date: May 2007 Location: UAE
Member: 513874 Status: Offline Thanks Meter: 178 | Quote:
Code: same problem here how to solve this need help from manole Just write modiefy PM with SDauth and chek info agaian | |
02-03-2010, 16:06 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | 3110c security test failed after sd repair Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...Update SPLOCK failed, you can try to upgrade/downgrade phone and retry ! |
02-03-2010, 16:37 | #8 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | You had ST_Security_failed in phone selftest and It can be solved by two ways. - Write good PM file field 1 and 309 - Phone has not sync or not available CCC and HWC data. So you need to rewrite from working phone. It works sometime. CCC - Common Configraution Certificate HWC - HardWare Certificate |
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
Nokia N96 Rm247 still security test failed after sd repair --Last Update -- | ABGSM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-11-2010 11:01 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Security Test Failed after SD Repair | adnann5 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-04-2010 06:58 |
FOR those who have SECURITY TEST FAILED after SD repair | hasnain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 15:13 |
