08-02-2012, 05:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Faisalabad Pakistan Age: 40
Member: 1562066 Status: Offline Sonork: 100.1622824 Thanks Meter: 555 | Nokia 5233 after full flash still on vibration i have a Nokia 5233 first take backup then full erase this is my mistake now set is dead i have latest version with same product code but hand set still on vibration any expert give me solution if have i,m very thank full to all my helpers Last edited by 6622622; 08-02-2012 at 06:04. |
The Following User Says Thank You to 6622622 For This Useful Post: |
08-02-2012, 06:11 | #2 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: pakistan,mansehra, MyFoneShop
Member: 1454923 Status: Offline Sonork: [email protected] Thanks Meter: 9 | Quote:
show logs og rpl and simlock etc | |
08-02-2012, 13:27 | #4 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | now i m bzy but i have special for u if u fail but first try to erase it maually come at sonorok if u not get erase file try maually erase via file may be u undestand |
08-02-2012, 14:08 | #8 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | tis set come this problem with ERASE. problem is flash chip not erase fully but with some erase file can do something u need t try, this situation ur set can be brick. B,R- |
08-02-2012, 16:03 | #10 (permalink) | |
No Life Poster Join Date: May 2012 Location: PARADISE ON EARTH(KASHMIR)
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Quote:
08-02-2012, 16:56 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. What you done before leave it, again follow Erase Method from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ with Nasty Uni Erase File attached below will erase full Flash Chip. Use FiRe Agent & Download Latest Firmware of your Phone with same Product Code of your Phone, can check Battery Back for the same. After Flash Write Full PM then Restore IMEI, Click Buscheck & post Logs as well as Result for the same. BR, ZUBER |
08-03-2012, 07:48 | #15 (permalink) | |
Member: 1562066 Status: Offline Sonork: 100.1622824 Thanks Meter: 555 | Quote:
