Old 11-24-2010, 08:57   #1 (permalink)
Member: 269885
Thanks Meter: 50
nokia c5 flashing error
i have nokia c5 powerd off,acording to costomer once it hanged and wen he remove batery and insert it back phone not powerd on.i tried to flash wid mxkey via usb it gave the following error.flashing log is
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Processing MCU file: rm645_032.010_prd.core.fpsx
[BB5,XSR 1.6] size: 90.95 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 391CE133
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 07400207421F004904EAB7207C67B3E8A634FE62
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Secondary boot loaded.
FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
Loading CMT update server data
Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123
Update server code loaded.
Verifying communication to device OK.
Reading CMT NPC Reading CMT VARIANT Flashing terminated with error(s) in 21.500 s
any one have any idea about this error (s),any solution for this problem.he baught the fone 5 days ago.
thx in advance
Old 11-24-2010, 09:26   #2 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
flash in latest version use fbus cable and atf interfranse
Old 11-24-2010, 09:47   #3 (permalink)
SHIBLU's Avatar
Member: 537829
Thanks Meter: 96
May be not full support for c5 in mx key.
Today i checked with fbus cable.
Not read security code in mx key.
Also not work factory setting.
Show done but not change old security code.
Old 11-24-2010, 09:58   #4 (permalink)
SHIBLU's Avatar
Member: 537829
Thanks Meter: 96
Thumbs down
Originally Posted by .:::parash:::. View Post
now supported c5 in mx key.
bro, chek ur cable.................
Br,
Parash
BRO READ MY POST........
I WROTE THAT May be not full support for c5 in mx key.
Old 11-24-2010, 10:00   #5 (permalink)
Cheater -Don't Deal with him-
Member: 410574
Thanks Meter: 139
flash version 032.010 with dead USB. Tested 10000000% OK with MX-key,,
Thanks MX-KEY team..
mcu = rm645_032.010_prd.core
ppm = rm645_032.010_05.01_Russian_prd.rofs2.fpsx
cnt = rm645_032.010_U000.000_prd.uda.fpsx
Tested 1000000% all OK...
Old 11-24-2010, 11:51   #6 (permalink)
Member: 269885
Thanks Meter: 50
i aslo tried wid fbus cable and recive the following log
Version from phone: 031.022
Version from file: 032.010
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Reading phone`s ID ...
Custom loader not available for this ID !
Restarting phone ...
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B40
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Please select correct loader version from 'Config' menu !
Read Certificate failed.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
any other idea?
Old 11-24-2010, 15:40   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
NPC_DATA is empty.
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
any other idea?
currently, UFS_USB V2.8 is not support flash operation.
you will need atf as interface to do flash bus operations.
or, simply use nokia usb rom if you want to flash it.
Old 11-25-2010, 03:56   #8 (permalink)
Member: 174952
Thanks Meter: 2
what about Jaf 01.b4, is it support for fbus flash operation c5?
thank's in advice.
Old 11-26-2010, 06:23   #9 (permalink)
Member: 269885
Thanks Meter: 50
i have no atf intrface however i mantiond in my 1st post first of all i tried wid nokia usb rom and got no success.i also tried flashed it wid ub and mtbox also but failed.i wll try to find atf as interface and wll post result
Old 11-26-2010, 06:25   #10 (permalink)
Member: 1180518
Thanks Meter: 23
i think only atf fully supported for flashing
Old 01-29-2011, 09:59   #11 (permalink)
Member: 160836
Thanks Meter: 3
anay one c5 flash by usb ubw
flash file version 032.010 done:
Page generated in 0.21135 seconds with 9 queries
