11-24-2010, 08:57 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in gsm world
Member: 269885 Status: Offline Thanks Meter: 50 | nokia c5 flashing error Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm645_032.010_prd.core.fpsx [BB5,XSR 1.6] size: 90.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 391CE133 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 07400207421F004904EAB7207C67B3E8A634FE62 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 391CE133 Verifying communication to device OK. Reading CMT NPC Reading CMT VARIANT Flashing terminated with error(s) in 21.500 s any one have any idea about this error (s),any solution for this problem.he baught the fone 5 days ago. thx in advance |
11-24-2010, 09:47 | #3 (permalink) |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | May be not full support for c5 in mx key. Today i checked with fbus cable. Not read security code in mx key. Also not work factory setting. Show done but not change old security code. |
11-24-2010, 10:00 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2006 Location: AM
Member: 410574 Status: Offline Thanks Meter: 139 | flash version 032.010 with dead USB. Tested 10000000% OK with MX-key,, Thanks MX-KEY team.. mcu = rm645_032.010_prd.core ppm = rm645_032.010_05.01_Russian_prd.rofs2.fpsx cnt = rm645_032.010_U000.000_prd.uda.fpsx Tested 1000000% all OK... |
11-24-2010, 11:51 | #6 (permalink) |
Member: 269885 Status: Offline Thanks Meter: 50 | i aslo tried wid fbus cable and recive the following log Version from phone: 031.022 Version from file: 032.010 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Reading phone`s ID ... SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Custom loader not available for this ID ! Restarting phone ... CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 07400207421F004904EAB7207C67B3E8A634FE62 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! Read Certificate failed. NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK any other idea? |
11-24-2010, 15:40 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
you will need atf as interface to do flash bus operations. or, simply use nokia usb rom if you want to flash it. BR | |
11-26-2010, 06:23 | #9 (permalink) |
Member: 269885 Status: Offline Thanks Meter: 50 | i have no atf intrface however i mantiond in my 1st post first of all i tried wid nokia usb rom and got no success.i also tried flashed it wid ub and mtbox also but failed.i wll try to find atf as interface and wll post result |
