02-24-2010, 13:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 381168 Status: Offline Thanks Meter: 935 | Updating SIMLOCK ... error 0x1 100% SOLUTION 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) [B](If required Recover Cert) |
The Following User Says Thank You to Jilani001 For This Useful Post: |
02-24-2010, 14:01 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Hello Br, Already given solution why again open new thread spam, Here is the link, https://forum.gsmhosting.com/vbb/f550/updating-simlock-error-0x1-100-solution-933709/ | |
5130 Updating SIMLOCK...error 0x1 | bhaskarsha | Nokia Base Band 5 ( BB-5 ) | 23 | 09-11-2011 18:51 |
!!! [+] Updating SIMLOCK ... error 0x1 100% SOLUTION !!! | Y.P.Y | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 42 | 12-11-2010 09:57 |
!!! [+] (3110) Updating SIMLOCK ... error 0x1 100% SOLUTION (Video Manual) WITH MXKey | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-29-2010 10:02 |
5220 Updating SIMLOCK...error 0x1[SOLVED] | gsmfeng | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 02-09-2010 09:19 |
