Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 07-05-2005, 03:51   #1 (permalink)
Member: 135184
Lead, cant attach k750 via cruiser, cable is right.
Hi, Lead,
When attaching k750, cruiser froze here, and two or three minutes later, "Script error: Unspecified [4.20.29]" occured, have tried any speed, and phenomenon are still the same? Any hints for it?
thanks in advance.
Originally Posted by Cruiser 4.20 Log
Baudrate = 460800Bd
Sony Ericsson phone detected.
Phone CID: 36
Phone color: Red
Trying Red CID36 flash applet...
Trying CID29 recovery applet...
All threads terminated.
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 115200Bd
Phone CID: 36
Phone color: Red
Old 07-05-2005, 07:22   #2 (permalink)
Member: 135184
hi,
Where is the support? Cruiser staff all on vacation?
best regards
Old 07-05-2005, 13:55   #3 (permalink)
Member: 135184
Hi,
Lead here.
best regards
Old 07-05-2005, 14:15   #4 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
u can try Force RSA Recovery mode to boot ur phone.
Repair Certicficate.
BTW did u test use UC-10 cable?
Old 07-05-2005, 16:47   #5 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
Are you using 3.0-3.5v or more or less??
Old 07-05-2005, 18:08   #6 (permalink)
Member: 10946
Thanks Meter: 15
I have the same problem with a k750i
The problem started when i tried to change language but it kept stopping while flashing.
I full charged the battery, my cable is for 3v and now when i try to attach phone and it displays the same error as yardh's phone.
I tried force recovery mode for cid 36 but when i press repair certificate it fails.
The phone is brand new and the customer is waiting
Old 07-06-2005, 05:40   #7 (permalink)
Member: 10946
Thanks Meter: 15
Any solution for this problem people?
Maybe a solution from cruiser team?
Old 07-06-2005, 09:26   #8 (permalink)
Member: 135184
Hi,
Thanks for your kindly replies.
I use cruiser 4 in 1 cable, which connect each other between two parts via PS/2.
I also use a DC3.3v power supply, as you see, cruiser can detect CID and chipid information.
Any other hints? Maybe Lead have solution.
best regards
Old 07-07-2005, 03:11   #9 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 469
Can anyone take a nice picture of connector internals?
Old 07-07-2005, 07:19   #10 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
for me i always use DC power supply then the cable i clip to power supply
means cable voltage is same as i clipping the phone to boot
works 100% for me
Old 07-07-2005, 09:23   #11 (permalink)
Member: 80202
Thanks Meter: 2
what dc power supply do you use? and how strong is it?
and sorry my english is not so good
works 100% for me
Old 07-07-2005, 15:32   #12 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
its normal DC power supply
tune to 3.6v enough
Old 07-07-2005, 15:32   #13 (permalink)
Member: 21920
Thanks Meter: 10
Here are two, keyboard up. Sorry if the quality is not great but I tried
By the way, Hyperterminal does not react at all with this cable, but it does with the t28 lead and the same uc10.
Old 07-07-2005, 15:52   #14 (permalink)
Member: 21920
Thanks Meter: 10
Here are the pins:
5-orange
6-brown
7-empty
8-red 3v+
9-GND black 3v- and green
10-red
11-black
12-yellow
Now I am trying to compare these to t28 that is in set and working.
Old 07-07-2005, 17:46   #15 (permalink)
Member: 21920
Thanks Meter: 10
I got it working. It seems the PS2 connectors in some Teleway cables are not set up right.
I disassembled the T28 connector (the one I tested OK) and used the wires to solder to the k750 connector.
At least in mine:
Brown = DTMS
Orange = DFMS
Red = CTMS
Black = CFMS
Green = GND
Yellow = IGN
The colors are the same in both connectors so just match them to their previous locations.
A picture of the new cable is below. Note the new battery assembly- it outputs about 3.4v with 2 AA batteries and has a nice easy clip at the top. Cost me $1
how UNlock 3500 via usb Cable. is real UNlocking by USB residentdenuevo Cyclonebox 3 02-12-2010 20:26
Unlocking via data cable is paid service?? ekotek SAGEM JTAG UNLOCKER 2 12-07-2007 19:17
k750 wont attach via usb cable in blink mode irfan99 Cruiser Suite 4 03-19-2007 15:37
cant attach k750 with testpoint smart_mobile Cruiser Suite 7 11-20-2006 14:56
Help I cant attach K750 Weasley Cruiser Suite 8 07-03-2005 15:21
Page generated in 0.24794 seconds with 10 queries
