07-03-2005, 12:48 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Do you have power attached to the cable? Is the battery fully charged? Contacts on the bottom of the phone clean? Have you removed the battery and reinserted it, then tried to attach? Sometimes just powering off the phone doesn't leave it in a state so that it can be attached to. |
07-03-2005, 12:55 | #4 (permalink) |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | Which cable do you use? I mean extra connector or included with your cable? I asked for that coz if it is extra connector then check the pinout again please. For me,I use old Fighter cable(has PS2 connector ) with extra K750 teleway connector(I have just modified pinout before using it). Hope that thing can help you out. Best regards |
07-03-2005, 12:56 | #5 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | No! 3 volts. Search here a little. I don't have any hands on experience with these phones so I'm a little out of my depth. It's been discussed here quite a few times though. |
07-03-2005, 12:58 | #6 (permalink) | |
Member: 33804 Status: Offline Thanks Meter: 22 | Quote:
Please open your cable and see,if it contains 78l05 IC then use 9V. Otherwise,please use 3V only Best regards | |
07-03-2005, 15:21 | #9 (permalink) | |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 58552 Status: Offline Thanks Meter: 24 | Quote:
if you use two AA batteries that would give you 3V but after battery power gose down you'll have a problem again. I would recomend a multi volte adapetor. Read would be for (+) and black will be for (-) | |
Please help - i can't attach k800 and k750 | Nikola Jolov | Cruiser Suite | 6 | 03-23-2007 13:26 |
cant attach k750 with testpoint | smart_mobile | Cruiser Suite | 7 | 11-20-2006 14:56 |
Lead, cant attach k750 via cruiser, cable is right. | yardh | Cruiser Suite | 16 | 08-18-2006 20:46 |
help!!!Cant attach p900 PDA Part~ | shingo000 | Cruiser Suite | 0 | 08-22-2004 06:16 |
Cant attach t68ie..... help | Keller | Cruiser Suite | 3 | 04-09-2004 17:38 |
