Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-27-2007, 13:46   #1 (permalink)
Member: 239168
Thanks Meter: 104
A New User Doubt About K800i Gdfs Error During Complete The Phone--help
I AM A NEW USER OF CRUISER.PURCHASED LAST WEEK.HAVE NOT DONE SE IN IT BECUASE I HAVE SE TOOL SINCE SIX MONTHS.TO STUDY MORE PURCHASED CRUISER.
NOW I HAVE A K800I DEAD.CUSTOMER SAID THAT REMOVED BATTERY WHEN TURN ON(I MEAN WITHOUT TURN OFF).THEN NEVER TURN ON.
AS USUAL FIRST TIME I TRIED IN SE TOOL.( I HAVE EXPERIENCE IN IT ONLY BECAUSE I AM NEW CRUISER USER)
WHEN CLICKED IN IDENIFY GOT AS BELOW
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:2019
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED
FLASH CID:49 COLOR:RED
set_gdfs_props failed, exiting
Elapsed:7 secs.
THEN I TRIED FLASHING USING CID49 FILES AFTER TICK TWO OPTIONS IN SETTINGS.COMPLETE THE PHONE AND USE SERVER FOR UNLOCK/FLASH AND GOT AS BELOW
Open COM port OK
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
Flash ID check:2019
Flash props sent ok
writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_1250568_HUTCHISON_WI.ssw.cry
CURRENT FLASH FILE CID:49
SSW uses complete hash, hash len is:9100
Will flash 455 blocks...
SSW loading returns:0
writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_HUTCH_1_fs.ssw.cry
SSW uses complete hash, hash len is:4420
Will flash 221 blocks...
CSloader version:
061027 1723 HANCXC1250562_DB2020_CSLOADER_R3A005
loader startup: executed
loader filesystem startup: executed
csloader refused to start GDFS services,error is:29
loader GDFS startup failed, that is fatal
Elapsed:613 secs.
FLASHING MAIN AND FS NO PROBLEM.BUT AN ERROR DURING COMPLETE THE PHONE
''''''''''loader filesystem startup: executed
loader GDFS startup failed, that is fatal""""""
I HAVE CRUISER LOGS ALSO.
CAN I REPAIR IT IN CRUISER?
IF YES-I WANT A DETAIL PROCEDURE TO REPAIR IT OR A LINK TO ABOVE DISCUSSIONS.
THANK U
Old 05-27-2007, 17:17   #2 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
Upgrade EROM ........
Old 05-27-2007, 18:34   #3 (permalink)
Member: 239168
Thanks Meter: 104
I TRIED UPGRADE EROM AND GOT AN ERROR AS BELOW
SERVER SUPPORT ENABLED.
RECOVERY MODE STARTED
DB2020 EROM UPGRADE STARTED
OLD EROM, OVERRIDING CID
error while reading security units
SECURITY UNITS CAN'T BE READ !
PHONE IS EMPTY OR GDFS IS DAMAGED.
Elapsed:9 secs.
SO I THINK IN MY SET GDFS DAMAGED.
CAN I RESTORE USING CRUISER?
IF YES HOW?
THANK U
Old 05-27-2007, 19:10   #4 (permalink)
mauro1947's Avatar
Member: 173538
Thanks Meter: 258
The phone has a GDFS damaged.
You must use Se Tool to fix it (Cruiser can't )
Regards!
Old 06-02-2007, 08:55   #5 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Elapsed:9 secs.
IF YES HOW?
THANK U
did you used ufs to update erom ??
if not then try
if same
forget this phone..
as far as ur pm i checked ur log ur gdfs is formated
say bye bye to your phone...
no tool is able to recover k800i gdfs..or any db2020 gdfs...
ps:how can they?no one able to CRACK RSA 1024...****ING *******..HELL WHAT CAN BE DO IN IF RSA SING INCREESS TO 2048 ...
Old 06-02-2007, 16:22   #6 (permalink)
Member: 40820
Thanks Meter: 12
press erom on cruiser it wil update the erom and hopefully fix yoour fault
Old 06-02-2007, 16:25   #7 (permalink)
Member: 67277
Thanks Meter: 5,588
We are now researching the solution to help you. Please be patient.
Old 06-02-2007, 20:31   #8 (permalink)
freakyass's Avatar
Member: 154522
Thanks Meter: 48
Open COM port OK
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed:7 secs.
Open COM port OK
Speed:921600
Flash ID check:2019
Flash props sent ok
CSloader version:
Elapsed:613 secs.
THANK U
maybe not a software problem, i just had same situation like this then i got to change the "vincent" ic and its works normal again. maybe the "vincent" ic include driver or something but i dont know its works for me. same problem that i have that my customer remove battery without turning off the phone and i really fix this phone bro. regards
Old 06-07-2007, 11:03   #9 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Lots of K800 have this problem. It's a GDFS fault. I hope that Cruiser will find a solution asap..
K320 NAK error during completing/customizing the phone! MUNEEB_AKHTAR_RAZA SETool2 7 02-13-2010 11:48
k800i gdfs error! cellmicro Universalbox 1 09-08-2009 08:17
k800i gdfs error how to do it? scion Sony Ericsson 1 11-24-2007 16:30
W550i can't complete the phone after flash by SEMC tool 7.0........Please help superwing1248 SonyEricsson (USB-Smart) 7 04-13-2006 14:37
W550 Error during Complete Phone sanshi SonyEricsson (USB-Smart) 0 03-25-2006 14:11
Page generated in 0.19467 seconds with 9 queries
