04-25-2005, 06:12 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Age: 56
Member: 84639 Status: Offline Thanks Meter: 2 | Old Cable Figther Problem. I have this problem.. in the past (few months ago) my Figther.. suddenly don't work more. The software work inclusively show the serial number but no detect my cable (the cable is original).. Help me please, BR |
04-25-2005, 08:56 | #2 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 43
Member: 52245 Status: Offline Thanks Meter: 4 | get screen Your Control Panel about PORT COM. Cruiser Detec Cabel max to 16 PORT and meaby PC detect Your cabel high port 17 ., 18 ..... etc Then You must go to COntrol Panel and manual select Fighter Cabel and set port Cabel to 10-16 port. And In cruiser get CLERA and Detect again. |
04-25-2005, 15:45 | #3 (permalink) |
Member: 84639 Status: Offline Thanks Meter: 2 | Spacewalker: Included screen photo with setup of com port, as you see it doesn't appear my old cable detected..also this cable is connected physical in my usb port, before it was detected and one day suddenly it was not detected any more. One more information before when the cable was conected to usb port my notebook gave me a ring but now it doesn't ring. BR |
04-25-2005, 22:18 | #5 (permalink) |
Member: 84639 Status: Offline Thanks Meter: 2 | Hi sven.soltermann: You were rigth, the cable is broken.., now it's repaired and the windows XP detect it but the figther still not, What's the problem??? For more information attached two screen. BR |
04-25-2005, 23:20 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Poland, Warsaw-Ursynow :) Age: 50
Member: 130649 Status: Offline Thanks Meter: 5 | I on cruiserze would see such solution: Start programme. 1."Settings "/ "connections setup: " - device I - interest clik, clik , laws cabel what you, np: "uc10-universal cable"," Fighter usb cable" ....itp. you- need detect what. On all harbours com from 1 to 16 so alone. 2. Confirm "connection / device" - button " OK" and lower "settings" 3. Button "rescan" , it should be after problem. Sorry for my English, from translates program. Interface fighter, cruiser is similar. Pzdr If it will not help repeat steps described by Spacewalker : get screen Your Control Panel about PORT COM. Cruiser Detec Cabel max to 16 PORT and meaby PC detect Your cabel high port 17 ., 18 ..... etc Then You must go to COntrol Panel and manual select Fighter Cabel and set port Cabel to 10-16 port. And In cruiser get CLERA and Detect again |
04-26-2005, 21:28 | #7 (permalink) |
Member: 52245 Status: Offline Thanks Meter: 4 | some problem i have when I instal Motorola Victor Dongle. Its some poblem in registry he have info about USb and CAN detect again new device in USB. (cabel and phone) If not help - You must search about Instal Victor Motorola and delete info in regisstry about USB - or remove USb controler in your PC and reset PC. Check cabel in other PC ? If cabel is damage - buy cabel for T630 - forever or other (to usb) and use Dawinchiteam solution for modifity cabel. Sometime I use Vygis USB box to flash Se but I must get POWER on The phone - dont have AutoIgnition. |
04-26-2005, 22:13 | #8 (permalink) |
Member: 130649 Status: Offline Thanks Meter: 5 | I use vygis uni-box (ftdi)- box additionally to se and lg, so autoignition has not, ale for this is recogniseable by cruiser as "Fighter USB cable", it was one should always button power on he near: Ready! Connecting via Fighter USB Cable... Powering on the phone... - power on Should the communication hang, reinsert battery. - power on Pzdr) Cezary It usb near different types of cables, when programme asks about new drivers usb, was it been possible was then to walk round in this way, not tested, and I do not command: -after installation and finding harbour described higher Settings / Options / Special options : Disable type cable veryfication - mark Last edited by Stokłosy11; 04-27-2005 at 08:01. |
where i buy 3in 1 old cable in pakistan | attique73 | SAGEM JTAG UNLOCKER | 0 | 10-05-2008 13:22 |
someone have schemes to mod old cables for hwk???? | pippone67 | Twisterflasher | 0 | 09-09-2005 10:07 |
do i needed to modify the old cable? | Jhungnd | Cruiser Suite | 5 | 11-28-2004 20:43 |
S55 with old cable - what's wrong? | tommiki | E-Gold Based Phones | 0 | 10-19-2003 21:58 |
C55 old Cable upgrade and Java Unlock | ycc | E-Gold Based Phones | 0 | 03-28-2003 08:17 |
