03-31-2008, 10:20 | #1 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 49
Member: 76072 Status: Offline Thanks Meter: 7 | PLS I NEED STEP BY STEP PROCEDURE HOW TO CHANGE K800i CID 49 TO 52 THANK YOU. |
03-31-2008, 12:03 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Be sure to upgrade the EROM before performing this conversion! To be able to flash red CID52 firmwares into red CID49/CID51 phones, these phones must be converted to CID52 first: · Attach the phone normally, then go to the GDFS tab, · from the Modify GDFS options list choose Upgrade to CID52 and press the Modify GDFS button. . · Then turn the phone off (for example by pressing the Finalize GDFS button). The CID will be upgraded during the next EROM code execution, i.e. during phone startup or boot via DCU-60 (while holding the C key). THIS IS TAKEN FROM THE MANUAL... of which you have on your PC. |
pls how to change from cid 49 to 52 w580 | TALIAT | SETool2 | 12 | 01-22-2014 15:46 |
how to write script to change k530i cid 49 to cid 52 with setool | med26 | Sony Ericsson | 2 | 03-19-2010 09:08 |
how to change db2020 cid 49 to cid 52 | ikram tabassum1 | SETool2 | 8 | 03-11-2009 17:13 |
้how to convert w850 cid 49 to cid 52 | t2520 | Universalbox | 2 | 06-15-2007 19:32 |
is that possible to change K800I cid RED49 TO cid brown? | geza | Cruiser Suite | 4 | 05-29-2007 08:59 |
