12-21-2005, 14:03 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 170494 Status: Offline Thanks Meter: 9 | problem RSA unlock k700i i try to unlock the RSA of k700i but it doestn unlock. i git the this log. can somebody help me please. Version 7.10 beta ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Brown Flash certificate: A1_SEMC Trying Brown CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Brown Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! Restarting phone... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Defeated! Sending CS applet... Done. Phone automatically detached. and i git this error message. No response from applet Error: Could not initialize GDFS access. |
12-21-2005, 21:54 | #2 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | hellwwwwwwwwwwwwwwwwwwwwwww Hellw, is there nobody to help me all this time. i am waiting for you cruiser teame. the phone is now doesnt work now. Iam sill waiting for you. |
12-21-2005, 22:19 | #4 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | yes with 7.10 i receive white screen phone...need to reflash it..bug inside 7.1...very interesting that 3 min. before have unlocked k700i same version same cid without problem...phone work ok 100%...next one white screen...and today is not witches night... |
12-21-2005, 23:31 | #5 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | Hallo thanks for your help but i hove still the same probleem also with the ver.6,10. i git this probleem and sorry for my bad english laguage. Version 6.10 ready! Charging ON... Charging OFF... Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! Restarting phone... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... i am still waiting for your help please. thaks |
12-22-2005, 18:50 | #9 (permalink) |
Member: 24435 Status: Offline Thanks Meter: 4 | yes..that is something reasonable...even if phone have plastic envelope on screen..i use setool/usbsmart/cruiser/gti...so noone of them untill now have damaged phone...Cruiser is very trustfull tool...you can not make mistake couse Lead have programmed working steps before, that is not case in other 3 tools... |
12-22-2005, 21:42 | #10 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 182006 Status: Offline Thanks Meter: 41 | I had something similiar with a red cid 29 k700i. As this is the first time I've used my cruiser I panicked and tried allsorts I kept reflashing it and got allsorts of problems.I then removed my (CHEAP ) usb hub and then flashed the phone and it worked . Check your connections ! and don't use cheap or cloned equipment. Steve |
12-23-2005, 06:39 | #12 (permalink) | |
Insane Poster Join Date: Sep 2005 Age: 60
Member: 183965 Status: Offline Thanks Meter: 0 | Quote:
12-23-2005, 10:28 | #13 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | Hello hi i tried it with the absolut new battery and full charged. now i can flash the ARM and write raw FS, but i get in the log that i must to reflash the firmware and now i dont fine enywere flash firmwhere. can somebody please tell me how i must reflash the firmware. thanks Again. Version 6.10 ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT |
Problem after unlock K700i :( | suliron | Cruiser Suite | 11 | 04-20-2007 16:33 |
STRANGE K750 CID49.on RSA section RSA UNLOCK and RESTORE buttons not active | *Diablo* | Cruiser Suite | 9 | 12-05-2006 09:15 |
K700i hang on the RSA unlock | bart3 | Cruiser Suite | 12 | 08-12-2006 12:48 |
How to relock RSA on K700i!? | GSMBlade | Cruiser Suite | 15 | 07-13-2005 03:47 |
k700i can't get RSA unlock | najafi | Cruiser Suite | 7 | 04-10-2005 20:14 |
