07-01-2006, 11:41 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Solution for "System diagnostics failed" found Follow these steps to view and remove these unnecessary device drivers:
07-01-2006, 13:04 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | Ha ha funny man - we had cable problems with drivers using different FTDI based cables the first time our cruiser died, then lead implemented this **** system diagnostics option. Now I aint saying that your fix doesnt work - but on my machine - this variable is automatically set - since installing windows. Now this might only apply to Windows XP SP2 users, as our machine uses XP SP2 and this variable was already there with a value of 1. br, Danny. |
07-01-2006, 15:44 | #3 (permalink) | ||
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
My variable is also set the same (though I'm not sure it was set to this 20 minutes after installing windows) - Not really the point of his post though, was it? I used to feel sorry for you and your company. Now I only wish Lead had also disabled your ability to post to this forum, funny man. | ||
07-01-2006, 16:27 | #4 (permalink) | |
Member: 21296 Status: Offline Thanks Meter: 328 | Quote:
Anyhow I posted this as this was my experience today and the problem was solved like a charm. | |
07-01-2006, 17:14 | #5 (permalink) | |
Member: 91298 Status: Offline Thanks Meter: 6 | Quote:
Full clean install of Windows XP SP2 OEM on our P4 3.0Ghz here, and it's genuine! we also own a computer store in our town and sell pre-built pc's to customer's specifications and provide a genuine copy of windows xp sp2 oem with each build we do. So I have used an OEM (genuine) for each of our machines that I built for the phone shop - the machines where built 8 months ago when I came back to work for Mobile-X-TREME, mainly becuase I left for a year so I could have a long break, when I came back we decided to build three new machines as the old machines where p3's and an Athlon 1800. Anyways - the brand new machine is a P4 3ghz, with windows xp sp2 and 1GB of Ram. Here is a copy of my system variables that where not touched since the install, bare in mind the install finished 5mins ago and im doing this to shut you up!. Code: Variable Value ComSpec C:\WINDOWS\system32\cmd.exe DEVMGR_SHOW_NONPRESENT_DEVICES 1 FP_NO_HOST_CHECK NO NUMBER_OF_PROCESSORS 2 OS Windows_NT Path %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Nokia\Update_Manager\bin PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH PROCESSOR_ARCHITECTURE x86 PROCESSOR_IDENTIFIER x86 Family 15 Model 2 Stepping 9, GenuineIntel PROCESSOR_LEVEL 15 PROCESSOR_REVISION 0209 TEMP %SystemRoot%\TEMP TMP %USERPROFILE%\Local Settings\Temp windir %SystemRoot% Now you also say - you used to feel sorry for me and my boss's company - that's a load of B O L L O C K S - you was the first person to backup Lead's claim's of me being a hacker or trying to spy on what cruiser was upto when i was working on phones. So don't contradict yourself - I will only shout back! I warned you now. Finally - why would Lead ban me from his forum, im a customer - and help others - fare enough I have dig's when people post useless information - but's thats what everyone does... so don't chat crap again - it wont get you anywhere. br, Danny. | |
07-01-2006, 17:22 | #6 (permalink) | |
Now if you meant a Specially made copy for me and wasnt referring to a non-genuine one, then did you mean a specialised ini file in the installtion package - becuase if this is case, I wasnt aware you could set variables in this, I thought this was for mainly telling windows what extra items to install from windows addon's etc and if you where to have a customised support section, like if I was to use a Dell XP CD - the installation is customised, you dont have to click any buttons apart from entering your cd-key for authenticity and clicking ok. Well - to clarify it for you, my Windows is a Genuine XP Pro SP2 OEM package. br, Danny. | |
07-01-2006, 17:39 | #7 (permalink) | |
Member: 21296 Status: Offline Thanks Meter: 328 | Can you tell me one thing? I think that you should own a flash disk for personal usage. You insert it into that clean installed PC and the PC installs drivers, and after that you use the flash disk (in this nobody can oppose. nor you). Then, you eject the flashdisk from the PC. Look after this if you can see the installed drivers for this device on Device Manager with the default options or not and then report here.... Although the variable is there 1, you are unable to view the hidden devices, till you do this procedure. Quote:
07-03-2006, 09:17 | #9 (permalink) | |
07-03-2006, 14:14 | #10 (permalink) | |
I removed the variable and rebooted, and put back the variable. Hidden devices are still not viewable by default, like you say - unless you go to the "View" menu and click "Show Hidden Devices" Now I change the variable to 0 and rebooted the machine, hidden devices have dissapeared - and the option to show hidden devices has gone. I think this variable is only to enable the "Show Hidden Devices" function from the "View" menu. I stand to be corrected tho... Anyways, I would like to leave it at this now, as the other poster said - a war has started over next to nothing, I might be to blame - and ill hold my hands up to it - so let's just end it now... I really can't be bothered. wbr, Danny. | |
07-23-2009, 03:35 | #12 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: No Location
Member: 87853 Status: Offline Thanks Meter: 1,231 | Quote:
ftp://zebulon.fr/DC3Setup_33.zip | |
solution for b13 b14 found!!!!!!!!!! | neogsm | Panasonic | 9 | 05-22-2008 11:55 |
plz send me the solution for SWS-Sagem Keynot found | ahmedmarten | SwS_SaG_BoX | 2 | 12-22-2006 21:23 |
!!! I found solution for 6210 Security Code Problem !!! | Brobble | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 39 | 05-08-2001 09:59 |
Hadak1-Did you found the solution for dead GD52??? | starpho | Panasonic | 3 | 04-16-2001 00:27 |
Is there any working solution for 6150 v5.20? All software found is fake!! | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-28-1999 10:54 |
