03-08-2008, 22:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | use something on your neck and the someting has two eyes, use them for reading the cruiser manual! enjoy the reading, very useful for you. |
03-09-2008, 19:26 | #5 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | its on the GDFS tab,,,,,,,, · Attach the phone normally, then go to the GDFS tab, · from the Modify GDFS options list choose Upgrade to CID52 and press the Modify GDFS button. · Then turn the phone off (for example by pressing the Finalize GDFS button). The CID will be upgraded during the next EROM code execution, i.e. during phone startup or boot via DCU-60 (while holding the C key). |
The Following User Says Thank You to THE CLASH For This Useful Post: |
03-09-2008, 19:37 | #6 (permalink) |
Freak Poster Join Date: May 2007 Location: albania Age: 37
Member: 511615 Status: Offline Thanks Meter: 35 | connect the phone using usb DCU-60 while holding ( C ) key go to GDFS tab,there you will see the button modify GDFS select upgrade to cid 52 then write raw fs with cid 52 unlock RSA flash arm with cid 52 then go to locks tab and click on direct unlock and finally make costumize fs. bye |
03-10-2008, 12:28 | #7 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | funny...maybe, but not my post but your post. you are lazy man. Cruiser has written manual for helps. Cruiser forum needs restriction like now SETool forum. When you post a rubbish message, will be deleted and you can receive BAN... BTW: about CID upgrade has been written lots of... regards, Filip |
05-02-2008, 11:58 | #9 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | Quote:
thanks,simple answer too a simple question... regards THE KOP... | |
The Following User Says Thank You to mint centre For This Useful Post: |
how to write script to change k530i cid 49 to cid 52 with setool | med26 | Sony Ericsson | 2 | 03-19-2010 09:08 |
how to change db2020 cid 49 to cid 52 | ikram tabassum1 | SETool2 | 8 | 03-11-2009 17:13 |
Sucessfully Unlock Z610 Convert Cid 49 To Cid 52 | kisna | SETool2 | 1 | 11-23-2008 11:28 |
Procedure to make Cid 49 to Cid 52 Sony ericsson phones | Matrix rev | HWK | 7 | 02-01-2008 12:52 |
้how to convert w850 cid 49 to cid 52 | t2520 | Universalbox | 2 | 06-15-2007 19:32 |
