07-19-2014, 12:33 | #466 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1210220 Status: Offline Thanks Meter: 5 | Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.20 AdvanceBox SN : DB3B6B60C49D965EA127FD4F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-19-2014, 12:35 | #467 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | when I activate I get this error ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : CEA4EB58C9368E558BB1F78F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ Report Post Edit/Delete Message |
07-19-2014, 12:40 | #468 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2114238 Status: Offline Sonork: ramco_tr Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : E91586F9CF47A953D2631A09 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-19-2014, 13:59 | #469 (permalink) |
Freak Poster Join Date: May 2010 Location: Turkey-Gallipoli Age: 44
Member: 1297771 Status: Offline Thanks Meter: 24 | User: tanerky Reseller: Ertan Bölük Turkey 18-07-2014 New Box ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : D81B1E1DE96B9C72FECE318E ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-19-2014, 14:04 | #470 (permalink) |
Junior Member Join Date: Jan 2004 Age: 52
Member: 51285 Status: Offline Thanks Meter: 7 | need activate Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : F905FD51824E22479D49FE11 |
07-19-2014, 15:10 | #471 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Cairo , Egypt Age: 34
Member: 2062433 Status: Offline Sonork: 100.1586838 Thanks Meter: 24 | Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : D9686BB88FB328EDE7C91DAD |
07-19-2014, 16:06 | #474 (permalink) |
Major Poster Join Date: Jan 2011 Location: BANGGAI
Member: 1499952 Status: Offline Sonork: 100.1661469 Thanks Meter: 2 | Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : F467D892C22560DADA8B4932 data 2014/05/23or2014/05/25 tank you |
07-19-2014, 16:20 | #475 (permalink) |
Member: 1499952 Status: Offline Sonork: 100.1661469 Thanks Meter: 2 | Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : F467D892C22560DADA8B4932 data 2014/07/19 tank you |
07-19-2014, 16:34 | #476 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2225415 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : EE2FDC1FA721055CF758BE20 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-19-2014, 18:29 | #477 (permalink) |
Member: 2214986 Status: Offline Thanks Meter: 0 | Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : E72B33A2A78E7B1385E625CA ========================================= last update 11/7/2014 Box Status : NOT ACTIVATED |
07-20-2014, 01:22 | #479 (permalink) |
Insane Poster Join Date: Apr 2012
Member: 1743497 Status: Offline Thanks Meter: 7 | Please helpmy box not working just from today my box already ACTIVATED but its not connect to server why is that please ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.20 AdvanceBox SN : A18274BCAD1859E4C6403A1C Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-20-2014, 01:52 | #480 (permalink) |
Member: 1499952 Status: Offline Sonork: 100.1661469 Thanks Meter: 2 | Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.50 AdvanceBox SN : F467D892C22560DADA8B4932 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done 20/72014 |
