Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-23-2014, 14:07   #1 (permalink)
Member: 2131081
Sonork: 76543322223
Thanks Meter: 92
another lumia 820 bricked when flashing
PHP Code:
19:06:32 Only Phoenix.ini Flash Files are
19
:06:32 supported for Checksum Verification...
19:06:35 Windows Phone 8 Flashing Started
19
:06:35 Loading Flash Files Please Wait...
19:06:39 :
19:06:39 : ======================================================
19:06:39 :             Windows Phone 8 Lumia Flasher
19
19:06:39 :
19:06:39 : If the Phone is ALIVE
19
:06:39 :   1. Power On the Phone and Connect it to the USB Port
19
:06:39 :
19:06:39 : If the Phone is DEAD
19
:06:39 :   1. Connect Phone to the USB Port
19
:06:39 :   2. Press and Hold the VOLUME DOWN and POWER Buttons
19
:06:39 :   3. Wait until the Phone Vibrates Shortly...
19:06:39 :   4. Stop Pressing the Buttons...
19:06:39 :
19:07:17 IMEI354105052744595
19
:07:17 Version1.1.1.3
19
:07:17 Product Code059R0H7
19
:07:17 Module Code0205162
19
:07:33
19:07:33 Boot Flash Mode Successful...
19:07:33
19:07:33 Phone Info Query Start...
19:07:33 Blocks Returned0x07 Blocks
19
:07:33 Block ID 0x01 :00241000
19
:07:33 Block ID 0x02 :00240000
19
:07:33 Block ID 0x03 :00ED0000
19
:07:33 Block ID 0x05 :Nokia.MSM8960.P5174.3.2.1
19
:07:33 Block ID 0x0D :0001
19
:07:33 Block ID 0x0F :0301010100000101FF
19
:07:33 Block ID 0x10 :0100030000
19
:07:33 Checking SD Card Size...
19:07:33 Card Size0x00000000
19
:07:33 Checking Platform Security Status...
19:07:33 Platform Secure Boot StatusActive
19
:07:33 Secure FFU EFUSE StatusActive
19
:07:33 Debug StatusActive
19
:07:33 RDC StatusNot Active
19
:07:33 Authentication StatusNot Active
19
:07:33 UEFI Secure Boot StatusActive
19
:07:33 Checking Secure FFU Mode...
19:07:33 Secure FFU Mode SYNC ASYNC
19
:07:33 Query Flash App Information...
19:07:33 Flash App Information02010E011900
19
:07:34 UEFI AppFLASH APP
19
:07:34 Flash App Protocol Version1.14
19
:07:34 Flash App Implementation Version1.25
19
:07:34 Query ROOT KEY HASH...
19:07:34 ROOT_KEY_HASHDB73418E5840941CE7BD35949085B8F74628D511F19285A092ED3B600A64CC29
19
:07:34
19:07:34 Sending Image Signatures...
19:07:34 Image Signatures Accepted!
19:07:34 Erasing Data Partition...
19:07:34 Data Partition Erased Successfully
19
:07:34 Preparing Buffers for DATA LOOP...
19:07:34 Allocating System RAM OK!
19:07:34 Start Sending DATA BLOCKS...
19:10:43 ERRORLAST DATA BLOCK REJECTED!
19:10:43 Check your Flash File and Phone Connection
19
:10:43 ERRORFlashing Failed
how to recover it? please help me urgent
Old 04-23-2014, 14:09   #2 (permalink)
Member: 1899191
Sonork: 100.1625109
Thanks Meter: 136
ur fone bettery low
u need to charge battery full and then try again
Old 04-23-2014, 14:58   #3 (permalink)
Member: 2131081
Sonork: 76543322223
Thanks Meter: 92
Originally Posted by Malik_GSM View Post
ur fone bettery low
i already tried with fully charged from working phone.
Old 04-23-2014, 16:40   #4 (permalink)
Member: 2131081
Sonork: 76543322223
Thanks Meter: 92
is there any clue to repair it without jtag?
Old 04-23-2014, 17:02   #5 (permalink)
Registered User
Member: 1591924
Sonork: 100.1636374
Thanks Meter: 12
Are you sure you have the correct flash file
Old 04-23-2014, 17:07   #6 (permalink)
mobite's Avatar
Member: 1800009
Sonork: 100.1654307
Thanks Meter: 806
lumia
download latest version flashfile and flash
Old 04-24-2014, 06:04   #7 (permalink)
Member: 2131081
Sonork: 76543322223
Thanks Meter: 92
ok,
resurrected with Great Riff and flash with ATF with same flash file
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.37, JTAG Manager Version: 1.55
Selected Resurrector: [Nokia Lumia 820 V1.0.5040.65102]
Connecting to the dead body...OK
Detected dead body ID: 0x706B40E1 - IGNORED!
Set I/O Voltage reads as 1.80V, TCK Frequency is 4 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (008G4B, 0x0001DA000000 Bytes = 7.41 GB)
Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (008G4B, 0x000000200000 Bytes = 2.00 MB)
Selected Resurrection Data for the eMMC Chip with Capacity = 7.41GB
Flashing the dead body...OK
Resurrection complete!
Version: 1.1.1.2
Product Code: 059R0H7
Module Code: 0205162
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00ED0000
Block ID 0x05 : Nokia.MSM8960.P5174.3.2.1
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100030000
Card Size: 0x00000000
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Secure FFU Mode : SYNC + ASYNC
Flash App Information: 020109011000
UEFI App: FLASH APP
Flash App Protocol Version: 1.9
Flash App Implementation Version: 1.16
ROOT_KEY_HASH: DB73418E5840941CE7BD35949085B8F74628D511F19285A092 ED3B600A64CC29
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:02:24
Page generated in 0.20669 seconds with 8 queries
