03-13-2014, 23:14 | #20 (permalink) |
Freak Poster Join Date: Oct 2013 Location: italy
Member: 2048673 Status: Offline Thanks Meter: 62 | Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.10 AdvanceBox SN : 9C4B7028D4CEE566B3018947 Box Status : ACTIVATED ================================================ Box Successfully Initialized JTAG Module: ACTIVATED JTAG Activation Done! Default language ID 0x0410 JTAG Interface ATF Box init failed! !!!!!!!!!!!!!!! Last edited by Winner58; 02-01-2015 at 20:53. Reason: quote removed |
03-14-2014, 08:13 | #21 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
03-15-2014, 17:13 | #24 (permalink) |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.10 AdvanceBox SN : 86A41B21D83B51759B26CF1E Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done JTAG Module: ACTIVATED JTAG Activation Done! Default language ID 0x0419 JTAG Interface ATF Box init failed! Cannot activate as well playing with computer like an idiot whole hour |
03-15-2014, 17:41 | #25 (permalink) |
Member: 196126 Status: Offline Thanks Meter: 80 | when im trying to activate it redirecting me to my paypal .... im using 1.06 version installed and 11.10 but i installed jtag after what to do |
03-16-2014, 18:17 | #26 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @ALL You guys are NOT paying attention to the instructions... Please read the first post again. 9. DO NOT ACTIVATE JTAG USING ATF Software v11.10!!! 10. Run ATFJ.exe (ATF JTAG Software 1.06 or higher...) |
03-17-2014, 12:13 | #27 (permalink) |
Member: 196126 Status: Offline Thanks Meter: 80 | all is well Thx all is well just reinstalled pack with 11.00 activated with one and run 11.06 module so might be all had same problem just use 11.00 for activate dont read explanation dont use sotware as Angel said DONT USE 11.10 |
03-17-2014, 19:57 | #28 (permalink) | |
Insane Poster Join Date: Feb 2009
Member: 974300 Status: Offline Thanks Meter: 8 | Quote:
Code: JTAG Module: NOT ACTIVATED JTAG Module Activation Cost: 39 Credits ERROR: You DO NOT HAVE enough Credits! Purchase JTAG Credits at ATF Store To ATF Team: Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.10 AdvanceBox SN : 9507D855B59454B0DBAE325C Box Status : ACTIVATED ************ ATF Box EEPROM Updated ************ Please Restart ATF Software... Install NEW ATF Box Drivers if needed... ************ ATF Box EEPROM Updated ************ ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Code: Default language ID 0x0409 JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...Activation Not Available Awaiting for the soonest solution. BR | |
03-18-2014, 06:12 | #29 (permalink) | |
Credit will added to your sl no after verification Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
03-19-2014, 07:10 | #30 (permalink) |
Junior Member Join Date: May 2008 Location: Valencia City Bukidnon
Member: 777406 Status: Offline Sonork: 0000 Thanks Meter: 2 | atf jtag problem Default language ID 0x0409 JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...Activation Not Available |
