01-29-2011, 08:59 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @manjunathcell This problem is caused when you DOWNRADE your FTDI Drivers by installing other boxes and clicking "YES" when Windows XP asks you if you want to overwrite the NEWER FTDI Drivers which is currently installed on your PC. This happens, because other Boxes from other teams are too lazy to update their drivers to newer 2010 ftdi drivers... The solution is very simple and is posted many many many many many many many many many many many many many many many many many many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many manymany many many many many many many many times already.... But for the sake of posting something useful other than blah blah,, here are the steps you should follow: 1. Check your Device Manager if it can find these 2 devices: USB to Serial Converter A and USB to Serial Converter B 2. If you see them, then download this from official FTDI Website: http://www.ftdichip.com/Drivers/CDM/CDM20808.zip 3. After you download it, extract it and use it to update the drivers of USB to Serial Converter A and USB to Serial Converter B. If you don't know how to update drivers in Device Manager, go here: 4. After you updated your drivers, retstart your PC just to make sure... 5. After you restart your PC, make sure you remove all your other boxes from the USB port... Connect only your ATF BOX: 6. Then go here: C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\ and run "MProg.exe" 7. Click --> "File" --> "Open" --> "new abox turboflasher.ept" 8. Click --> "Device" --> "Erase" 9. Click --> "Device" --> "Program" 10. Wait 5 seconds... Then disconnect the ATF BOX from your USB PORT and Close/Exit MPROG SOFTWARE. 11. Connect ATF BOX to USB Port and use these drivers: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS If you don't know how to install Device Drivers... Go here: 12. Check Device Manager now and see if you will find: AdvanceBox Turbo Flasher and AdvanceBox Programming Port 13. If you see them, you can now run ATF Software.... |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-17-2011, 20:46 | #4 (permalink) |
Junior Member Join Date: Nov 2008
Member: 894376 Status: Offline Sonork: 678012 Thanks Meter: 3 | thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo thank yuo |
***********P900 big problam key not work******** | Anand madaan | Sony Ericsson Hardware Repair | 13 | 02-26-2005 09:45 |
problam in 3410...ples help me? | amana24 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-17-2004 18:01 |
New Eric software V2.5 T630 Dead atf. Flash | DirkDeus | Twisterflasher | 1 | 02-27-2004 22:58 |
Hi i have a BIG BIG problam with my 3310 !! | p2pangel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-24-2002 23:11 |
sound problam | thangal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2002 09:44 |
