02-08-2014, 05:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: ??????
Member: 446199 Status: Offline Thanks Meter: 40 | ATF Team Need Help I have Recently brought ATF Nitro box I have installed the latest ver got problems & read many users getting problems with the driver(Have done most of the solution posted still no luck) Now i have installed a clean win 7 i just need to know that should i go for the latest update that is v11 or go for the old one Just looking for a clean install with the right files THX |
02-08-2014, 05:40 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Download v11.00 from here http://forum.gsmhosting.com/vbb/10068252-post2.html 1. Connect ATF Box and tell windows to use drivers from C:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_DRIVERS\ |
02-08-2014, 06:17 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Download here: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip After you install that. Run atf software, goto Product Support ---> Box Tools ---> Click "Restore EEPROM" Reconnect box... Then install using atf new drivers |
02-08-2014, 06:33 | #5 (permalink) |
Member: 446199 Status: Offline Thanks Meter: 40 | This is what i can't understand (Got this before re loading win) After install that driver it auto installs the rest Did Restore EEPROM but when i reconnect box it wont ask for the drivers as every thing is still installed |
02-10-2014, 13:54 | #10 (permalink) |
Member: 446199 Status: Offline Thanks Meter: 40 | Thats the problem if i remove the old drivers & Show it the new drivers it says the best drivers is already installed (sandeep56 & Just Unlocker dude pls read & post it in the right section) |
