12-17-2014, 02:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Tests Microsoft Lumia 535 WinPhone 8.1 !!! (Flashing and eMMC TP) ATF Lumia 535 WinPhone 8 Full Flashing! Also check out other Lumia WinPhone 8 Phones Flashed by ATF: http://forum.gsmhosting.com/vbb/f609...shing-1680792/ http://forum.gsmhosting.com/vbb/f609...8-1-a-1893234/ http://forum.gsmhosting.com/vbb/f609...shing-1680806/ http://forum.gsmhosting.com/vbb/f609...shing-1705355/ http://forum.gsmhosting.com/vbb/f609...shing-1821664/ http://forum.gsmhosting.com/vbb/f609...shing-1680803/ http://forum.gsmhosting.com/vbb/f609...mc-tp-1889137/ http://forum.gsmhosting.com/vbb/f609...shing-1575683/ http://forum.gsmhosting.com/vbb/f609...shing-1576227/ http://forum.gsmhosting.com/vbb/f609...shing-1576622/ http://forum.gsmhosting.com/vbb/f609...shing-1573787/ http://forum.gsmhosting.com/vbb/f609...shing-1680813/ http://forum.gsmhosting.com/vbb/f609...shing-1689895/ http://forum.gsmhosting.com/vbb/f609...shing-1727846/ http://forum.gsmhosting.com/vbb/f609...shing-1763465/ http://forum.gsmhosting.com/vbb/f609...shing-1746767/ You Can Download Flash Files Here: http://forum.gsmhosting.com/vbb/f609...added-1660094/ Microsoft Lumia 535 WinPhone 8.1 Flashed Successfully with ATF... Here are the Screenshot: Here are the Flashing Logs: Code: Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8/8.1 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== ================================================ Basic Phone Information ================================================ SW Version : 02048.00000.14457.51004 IMEI Plain : 357145060399187 IMEI2 Plain : 357145060399195 Phone Type : RM-1090 HW Version : 3000 Product Code : 059W6K1 Basic Product Code: 059W2B7 Module Code : 0206286 PSN Number : 530A42AAB Operator Name : 000-HK Phone Version : BuildDate : Nov 10 2014 , BuildType : Release , HelloString : NCSd for WP8 , Version : 5.0 Manufacturer ID : RM-1090_1020 Security Mode : Restricted ================================================ Extended Phone Information ================================================ Public ID : 64732CA75ACB6FA0B2DBF6ABA6B6D7907C3724FB Wireless Lan 0 ID: 20:62:74:EF:36:1C Wireless Lan 1 ID: 20:62:74:EF:36:1D Wireless Lan 2 ID: 20:62:74:EF:36:1E Wireless Lan 3 ID: 20:62:74:EF:36:1F Bluetooth ID : 20:62:74:EF:05:F4 ================================================ Simlock Information ================================================ SIMLOCK STATE : Not Locked Booting Flash Mode Initiated... Please wait upto 15 Seconds for HW Reset Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8212.P6214.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020222023B00 UEFI App: FLASH APP Flash App Protocol Version: 2.34 Flash App Implementation Version: 2.59 Query ROOT KEY HASH... ROOT_KEY_HASH: BC2353ACA62C327ECCD582A281CA4A5672F35001D87176CCBF3C87DBE215CA3B Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:08:01 FLASHING The Phone... BOOT Repair Tests will follow BR X-Shadow |
The Following 5 Users Say Thank You to Advance-Box For This Useful Post: |
02-11-2015, 09:57 | #3 (permalink) |
Junior Member Join Date: Apr 2011 Location: Kawasoti, Nawalparasi, Nepal
Member: 1550492 Status: Offline Sonork: 100.1617722 Thanks Meter: 2 | lumia 535 DUOS RM-1090 Microsoft Lumia 535 Duos not suported |
The Following User Says Thank You to manu ale For This Useful Post: |
05-30-2015, 18:13 | #5 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | when you try to write emmc file software will show you pinouts, FIRSY YOU HAVE TO DOWNLOAD EMMC TP FILE FROM HERE http://atfsupport.com/?dir=file-supp...Repair%20Files |
07-27-2015, 19:56 | #6 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 17/12/2014 (dd/mm/yyyy) Description: Lumia 535 RM-1090 BOOT [02048.00000.14457.51004] Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! EMMC Connect Error Operation Cancelled... Total Elapsed Time 00:00:18 ERROR: WRITE FAILED! |
08-07-2015, 14:03 | #8 (permalink) |
Junior Member Join Date: Mar 2010 Age: 42
Member: 1262115 Status: Offline Thanks Meter: 2 | Nothing happens. Can some body explain procedure, who have done this operation with sussecc ? Same problem like jatchaminda have NEED HELP Last edited by skachati; 08-07-2015 at 14:09. |
08-10-2015, 08:41 | #9 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | lumia 535 flash done with atf in few minutes Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x0A Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x04 : 00EA4000 Block ID 0x05 : Nokia.MSM8212.P6214.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00EA4000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020222023B00 UEFI App: FLASH APP Flash App Protocol Version: 2.34 Flash App Implementation Version: 2.59 Query ROOT KEY HASH... ROOT_KEY_HASH: BC2353ACA62C327ECCD582A281CA4A5672F35001D87176CCBF 3C87DBE215CA3B Query PUBLIC ID... PUBLIC_ID: DBC311D002AE376967A4778585E732AA9CDE1048 Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : A1E210AC EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 71% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:07:06 |
08-14-2015, 12:05 | #11 (permalink) |
Member: 1262115 Status: Offline Thanks Meter: 2 | MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 12/09/2015 (dd/mm/yyyy) Description: Lumia 535 RM-1090 BOOT [02048.00000.14457.51004] Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! EMMC Connect Error Operation Cancelled... Total Elapsed Time 00:03:18 ERROR: WRITE FAILED! ---------------- What type of problem ? Flash probably ? |
09-18-2015, 01:01 | #13 (permalink) |
Insane Poster Join Date: Dec 2008 Location: México
Member: 922779 Status: Offline Thanks Meter: 7 | Lumia 535 boot repair success, try using VCCIO: 1.80V Loading ATF MMC File... (Please Wait) ================================================== ==== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 17/12/2014 (dd/mm/yyyy) Description: Lumia 535 RM-1091 BOOT [02048.00000.14457.51001] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 3 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 4 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 5 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 6 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 7 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 8 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 9 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 10 Start Writing Blocks... Writing Blocks Done! Perform Firmware Update via USB Cable. Perform Firmware Update via USB Cable. Total Elapsed Time 00:02:15 Write Success! |
10-11-2015, 11:28 | #14 (permalink) |
Freak Poster Join Date: Apr 2012 Location: dubai ++ kerala ++ thalassery
Member: 1745727 Status: Offline Sonork: 100.1617904 Thanks Meter: 66 | lumia 535 DUOS RM-1090 Microsoft Lumia 535 Duos not suported HI MY ATF TEEM PLS HELP ME MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 17/12/2014 (dd/mm/yyyy) Description: Lumia 535 RM-1090 BOOT [02048.00000.14457.51004] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... EMMC Connect Error Total Elapsed Time 00:20:21 ERROR: WRITE FAILED! |
The Following User Says Thank You to sweathasreekant For This Useful Post: |
12-22-2015, 14:10 | #15 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 911152 Status: Offline Thanks Meter: 4 | Hello, sorry for gravedigging this post. The TP points for the eMMC can also be used for reading the eMMC right? does it work on any 535 model? except the DUOS of course, i don't need duos support |
The Following User Says Thank You to atomikramp For This Useful Post: |
