Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-22-2015, 10:58   #91 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 170
Driver Version : 00021000
Library Version : 00030207
Box Type : ATF Lightning
Box Firmware : LogiCore 11.0.10
Software Version : v12.40
AdvanceBox SN : D849DA11CA8B0D72E3EF4C4A
Box Status : NOT ACTIVATED
Old 10-23-2015, 21:56   #92 (permalink)
Member: 579107
Thanks Meter: 20
AdvanceBox SN : 9418EB83834E6A1DFC8DB1D8
Old 10-25-2015, 06:07   #93 (permalink)
Member: 1476691
sir my request was sent very long but still unsolved my box jtag active but does not remember the day I am active vacation should buy ATF half not
Old 10-26-2015, 07:16   #94 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Thanks Meter: 4,002
what happen to ATF Supporter Or Manager? Fast money when receiving and slow to solved *******r problem ? tsk tsk tsk
Old 10-27-2015, 08:38   #95 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
your box is blocklisted.
Old 10-27-2015, 08:39   #96 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
your box is blocked.
Old 10-27-2015, 08:41   #97 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Old 10-27-2015, 13:37   #98 (permalink)
Member: 1476691
sir I do not understand , with my box to death???thank sir
Old 10-29-2015, 06:19   #99 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 170
why it's blocked bro and How Solve this ?!
my reseller is dead ,can send pymnt to reactive?
Old 11-03-2015, 09:41   #100 (permalink)
Member: 2114238
Sonork: ramco_tr
Advance Turbo Flasher Found
AdvanceBox SN : E91586F9CF47A953D2631A09
Please Activate your Box
* Follow these Instructions
1. Disconnect any phones connected to ATF Box
2. Go to "Product Support Tab"
3. Go to "Box Tools" Section
4. Fill in the Required Information
5. Click "Activate Box" button
Box Successfully Initialized
Old 11-05-2015, 06:15   #101 (permalink)
ramdane21's Avatar
Member: 1882414
Sonork: 21000
Thanks Meter: 28
my atf netro is activated (jetag) last yares 2014 and ai work with heur mor than 50 times and today show mes tis
Checking ATF JTAG Activation from Server...ATF Box Not Activated for JTAG.
Checking ATF JTAG Activation from Server...Impossible d'établir une connexion avec le serveur
Default language ID 0x0409
JTAG Interface Connected, S/N 0xFC04162A
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 5/25/2014 6:53:00 PM
Phone Type : Samsung GT-S7562
CPU Type : Qualcomm MSM7227A
Storage TYpe : eMMC 4GB
Boot Package : Full Boot Restore (4.0.4)
1. Make sure JTAG Connection is 100% OK
2. Phone BATTERY should be CONNECTED!!!
3. Connect RJ-45 JTAG Cable to ATF Box
4. Connect USB Cable to the Phone
5. Click RESET JTAG button to check JTAG Connection
6. Click RESTORE BOOT button to Start Operation
Restore Boot...
Waiting for Device Connection 20 second(s)...Timeout During Operation!
AFP revision 4, compiled 6/10/2014 1:23:00 PM
Phone Type : Nokia XL [RM-1030]
CPU Type : Qualcomm MSM8225
Firmware Version: 1.1.1.0
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
AFP revision 4, compiled 7/20/2014 12:07:00 AM
Phone Type : Samsung SGH-M919N - Galaxy S4
CPU Type : Qualcomm APQ8064AB
Storage Type: eMMC Size: OPEN (16GB, 32GB, 64GB)
Boot Package: Android 4.3 - M919NUVUEMK5
and in 2015
ATF JTAG v1.0.15.8544 (17/06/2015)
Default language ID 0x040C, LR 14
AFP revision 4, compiled 26/11/2013 10:48:00
Phone Type : Lumia 610 RM-835 - Supported
: Lumia 610 RM-849 - Supported
: Lumia 610C RM-836 - Supported
Unlock Type : Read PIN and PUK Unlock Codes
Other Notes : Disconnect USB Cable before Reading Codes
4. Disconnect USB Cable from the Phone
5. DO NOT click RESET JTAG button
6. Click READ CODES button to Start Reading Unlock Codes
Disconnect USB Cable from Phone (If Connected)
Re-Connect USB Cable to Phone...
Connect USB Cable to Phone...OK
USB Connected! Waiting for First Event...OK
Disconnect USB Cable Now...OK
Waiting for Device Connection 10 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core with 300ms Delay...OK
Initializing Device...OK
Retrieving Unlock Codes...OK
Service Provider Unlock Codes Found
Level 1 PIN: 70795129 ACTIVE
Level 1 PUK: 91230605 ACTIVE
Level 2 PIN: 09848050
Level 2 PUK: 26533777
Level 3 PIN: 84863935
Level 3 PUK: 74570294
Level 4 PIN: 56609203
Level 4 PUK: 76490542
Level 5 PIN: 41239235
Level 5 PUK: 40276762
Reading Unlock Codes Done!
1. Remove JTAG Connection and Assemble Phone
2. Insert SIM Card from different Provider into the Phone
3. Power ON the Phone
4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it
5. After Code is accepted, wait 30 seconds until Operator Signal Appears
Write Down 8-digit PIN CODE on a piece of paper and attach
it to the phone under the battery. This will allow the owner
of the phone to unlock this phone again if he will flash the
phone firmware in the future.
Saving "..\Logs\Screenshots\2015-10-23_08-08-18.jpg"...OK
Old 11-13-2015, 09:31   #102 (permalink)
Crazy Poster
Member: 688901
Sonork: 1614241
Thanks Meter: 107
Box Type : AdvanceBox Turbo
Box Firmware : LogiCore 11.0.00
Software Version : v11.70
AdvanceBox SN : A73CB38BF6EEDBFF922A1659
Please Help Bro...
Thanks...
Br.
Alfajar Bestncheap
Old 11-18-2015, 21:45   #103 (permalink)
Member: 840399
Software Version : v12.20
AdvanceBox SN : C9375290FCCA9F9680DCCA17
Old 01-01-2016, 07:04   #104 (permalink)
Member: 923784
Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below:
Driver Version : 00021206
Library Version : 00030210
Software Version : v8.70
AdvanceBox SN : EC657F8FE6D69D3FF5B31529
Old 01-02-2016, 08:46   #105 (permalink)
Member: 923784
Page generated in 0.35361 seconds with 8 queries
