09-02-2013, 11:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Cherry Mobile Flare S100 - FULL REPAIR via eMMC Test Points Here is an alternative way to Fix Cherry Mobile Flare S100 via "more difficult" eMMC Test Points. You should only do this if: 1. Boot Repair via QPST eMMC Software Download gives you "Cookie not found" error. 2. ATF JTAG Factory Restore Does not work (gives you error eMMC Busy). 1. You did not Activate JTAG and want to do via eMMC TP only. How is this more difficult than JTAG? 1. You need to remove the metallic Shield under the back sticker of the phone. 2. The Test Point locations are very small and you need to have a microscope and good soldering skills. 3. You need to remove 1 resistor to make the Connection stable, and then replace this resistor with a "jumper wire" or just solder lead after the Full Factory Restore is done. 4. It takes 3 hours to restore 800 mb to the phone via eMMC TP while it only takes 40 minutes to do the same task via JTAG. For those of you who want to continue, here is the eMMC Test Point Connections... (You need ATF 10.11 from Auto Update Server). Here is the Phone All Wire Up: Some Screenshot half-way Through: And here is the phone after 3 hours...: Where is the 800 mb Repair File Sir ??????????? Please wait,, still uploading it... B.R. X-Shadow Last edited by Advance-Box; 09-02-2013 at 12:09. |
The Following 27 Users Say Thank You to Advance-Box For This Useful Post: |
09-02-2013, 15:24 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Factory Repair File Uploaded here: http://www.4shared.com/folder/D1yPkJ...AIR_FILES.html Instructions are all inside the RAR file... Last edited by Advance-Box; 09-02-2013 at 17:22. |
The Following 24 Users Say Thank You to Advance-Box For This Useful Post: |
09-03-2013, 04:56 | #3 (permalink) |
Freak Poster Join Date: Jul 2013 Location: multan
Member: 1976222 Status: Offline Thanks Meter: 53 | Factory Repair File Uploaded here Instructions are all inside the RAR file. 4shared folder - eMMC REPAIR FILES |
The Following User Says Thank You to Ejaz.bagra For This Useful Post: |
09-03-2013, 05:25 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | I need help sir Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED ERROR: Connection Refused 0x06 Check your Test Point Soldering! Total Elapsed Time 00:00:18 Write Success! |
09-03-2013, 06:27 | #5 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 2.8-2.9V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V ERROR: Connection Refused (CMD2) Check your Test Point Soldering! |
09-03-2013, 07:41 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @ALL if your eMMC is not detected and you followed all instructions 1:1. Then your eMMC is dead. If you are from the Philippines, and willing to wait for at least 1 week. I have ordered replacement eMMC chips. I will give 10 pieces free to Local ATF JTAG users (1 each maximum). But you need to remove the old eMMC and put back the new one yourself. Requires BGA reballing skills... B.R. |
The Following 14 Users Say Thank You to Advance-Box For This Useful Post: |
09-03-2013, 08:05 | #9 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V ERROR: Connection Refused 0x05 Check your Test Point Soldering! |
09-03-2013, 08:17 | #10 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
You removed Resistor the on the PCB right? ERROR: Connection Refused 0x06 <--- This is error read first block of eMMC... Means eMMC is detected but data is corrupted when it tries to read from your eMMC. | |
09-03-2013, 08:19 | #11 (permalink) | |
Insane Poster Join Date: Feb 2009 Location: Phillipines
Member: 975567 Status: Offline Thanks Meter: 7 | Quote:
see you in the phillipines | |
09-03-2013, 09:28 | #12 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1003445 Status: Offline Thanks Meter: 3 | hi, this is the error i get Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V ERROR: Connection Refused 0x04 Check your Test Point Soldering! |
09-03-2013, 09:32 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @white_beard If you follow instructions 1:1 and removed resistor before TP, then most probably your eMMC is also dead. I will put some BETA exe now which will show more logs on what data was detected from the eMMC before you get the error 0x04. 0x04 means 4th step is bad,, but 1-2-3 is ok. There are total 7 steps for eMMC initialize in ATF Software. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-03-2013, 09:58 | #14 (permalink) | |
Freak Poster Join Date: Oct 2009 Location: Pamplona Negros Phillippines Age: 41
Member: 1147721 Status: Offline Sonork: 100.1624168 Thanks Meter: 13 | so it cannot be done even atf jtag. need to replace emmc..how to select phone model in jtag chain?? Quote:
09-03-2013, 10:11 | #15 (permalink) |
Member: 1003445 Status: Offline Thanks Meter: 3 | I did remove the resistor probably my eMMC is faulty, cause sometimes i get this error Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 2.8-2.9V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.50-1.55V ERROR: Connection Refused (CMD2) Check your Test Point Soldering! |
The Following 2 Users Say Thank You to white_beard For This Useful Post: |
