09-03-2013, 10:13 | #16 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF JTAG is different EXE. To select phone model, is just select AFP File. All of which you can download here: EXE 1.0.1 atf_jtag_v1.01_exe_only - Download - 4shared AFP FILE FOR S100 cm_flare_s100_jbv006045 - Download - 4shared |
09-03-2013, 10:40 | #17 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V ERROR: Connection Refused (CMD2) Check your Test Point Soldering! |
09-03-2013, 13:37 | #18 (permalink) | |
Freak Poster Join Date: Oct 2009 Location: Pamplona Negros Phillippines Age: 41
Member: 1147721 Status: Offline Sonork: 100.1624168 Thanks Meter: 13 | i will wait for emmc.. the only solution if cannot revived using atf jtag is to replace emmc. thanks. Quote:
09-03-2013, 13:54 | #19 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @marvin62 JTAG is not possible to kill unless your phone really has bad hardware problems. JTAG is talking to MSM8225 CPU of phone and JTAG does not care if eMMC is alive or not... it should respond to ATF JTAG software and show his IDCODE. Please check again your wiring and check any capacitor in on your PCB to see if it is getting some voltage when you connect the usb cable. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-03-2013, 15:00 | #20 (permalink) | |
Member: 1147721 Status: Offline Sonork: 100.1624168 Thanks Meter: 13 | it is the pinout i followed . i connect orange pinout with one wire is that right??no need battery usb only i already check usb connector and its ok.. Quote:
The Following User Says Thank You to marvin62 For This Useful Post: |
09-03-2013, 16:22 | #22 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
br Max | |
09-03-2013, 16:50 | #23 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @maxpizza one is for eMMC Connection via ATF software - the one inside eMMC REPAIR FILES the other is for JTAG Connection via ATF JTAG software - the one inside ATF JTAG AFP FILES |
09-03-2013, 17:55 | #24 (permalink) | |
The other not find in ATF JTAG sw folder whith name ATF JTAG AFP FILES, need of copy/paste these downloaded file in ATF JTAG SW? | |
09-03-2013, 19:03 | #25 (permalink) |
Member: 125945 Status: Offline Thanks Meter: 495 | Ok now i've removed ATF JTAG FULL then have launched only the ATF JTAG EXE 1.01 and the downloaded AFP FILE FOR S100 now is in ATF JTAG AFP Files, ok. When launch the ATF FULL JTAG 1.01 have also List of Phones whith FULL BOOT files and Quick_Fix files, this can use if i want use JTAG SOLUTION and no Only TP. TP only i select from ATF SW and use eMMc side w/o JTAG, is correct now?, pardon but i've the same AFP FILE FOR S100 in ATF SW, and think has done a mistake.. Tx for reply Br |
09-03-2013, 20:03 | #27 (permalink) | |
Tx Br | |
