Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-02-2013, 11:58   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Cherry Mobile Flare S100 - FULL REPAIR via eMMC Test Points
Hi,
Here is an alternative way to Fix Cherry Mobile Flare S100 via "more difficult" eMMC Test Points. You should only do this if:
1. Boot Repair via QPST eMMC Software Download gives you "Cookie not found" error.
2. ATF JTAG Factory Restore Does not work (gives you error eMMC Busy).
1. You did not Activate JTAG and want to do via eMMC TP only.
How is this more difficult than JTAG?
1. You need to remove the metallic Shield under the back sticker of the phone.
2. The Test Point locations are very small and you need to have a microscope and good soldering skills.
3. You need to remove 1 resistor to make the Connection stable, and then replace this resistor with a "jumper wire" or just solder lead after the Full Factory Restore is done.
4. It takes 3 hours to restore 800 mb to the phone via eMMC TP while it only takes 40 minutes to do the same task via JTAG.
For those of you who want to continue, here is the eMMC Test Point
Connections... (You need ATF 10.11 from Auto Update Server).
Here is the Phone All Wire Up:
Some Screenshot half-way Through:
And here is the phone after 3 hours...:
Where is the 800 mb Repair File Sir ???????????
Please wait,, still uploading it...
B.R.
X-Shadow
The Following 27 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-02-2013, 15:24   #2 (permalink)
Member: 651945
Factory Repair File Uploaded here:
http://www.4shared.com/folder/D1yPkJ...AIR_FILES.html
Instructions are all inside the RAR file...
The Following 24 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-03-2013, 04:56   #3 (permalink)
Ejaz.bagra's Avatar
Member: 1976222
Thanks Meter: 53
4shared folder - eMMC REPAIR FILES
The Following User Says Thank You to Ejaz.bagra For This Useful Post:
Old 09-03-2013, 05:25   #4 (permalink)
Member: 575851
Thanks Meter: 544
I need help sir
Interface Reset OK!
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V
2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V
1.9-2.0V
eMMC Boot Information
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT: DISABLED
PWR_BOOT_CFG_PROT : DISABLED
eMMC FirmW UPDATE : DISABLED
ERROR: Connection Refused 0x06
Check your Test Point Soldering!
Total Elapsed Time 00:00:18
Write Success!
Old 09-03-2013, 06:27   #5 (permalink)
Temporary banned !!
Member: 1151970
Sonork: 100.1597000
Thanks Meter: 378
Interface Reset OK!
3.5-3.6V, 2.8-2.9V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V
ERROR: Connection Refused (CMD2)
Old 09-03-2013, 06:35   #6 (permalink)
Member: 975567
Thanks Meter: 7
Hard to connect
i follow all the procedure but nothing connect!
BOX type : CHROME
Old 09-03-2013, 07:16   #7 (permalink)
Member: 1900492
Thanks Meter: 8
THE SAME PROBLEM
Old 09-03-2013, 07:41   #8 (permalink)
Member: 651945
@ALL
if your eMMC is not detected and you followed all instructions 1:1. Then your eMMC is dead.
If you are from the Philippines, and willing to wait for at least 1 week. I have ordered replacement eMMC chips.
I will give 10 pieces free to Local ATF JTAG users (1 each maximum). But you need to remove the old eMMC and put back the new one yourself. Requires BGA reballing skills...
B.R.
The Following 14 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-03-2013, 08:05   #9 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect USB Cable to Phone
3. Connect the Soldered TP Connections to ATF Box
Interface Reset OK!
1.9-2.0V
ERROR: Connection Refused 0x05
Old 09-03-2013, 08:17   #10 (permalink)
Member: 651945
Originally Posted by ayhen42 View Post
I need help sir
Interface Reset OK!
1.9-2.0V
Write Success!
You removed Resistor the on the PCB right?
ERROR: Connection Refused 0x06 <--- This is error read first block of eMMC... Means eMMC is detected but data is corrupted when it tries to read from your eMMC.
Old 09-03-2013, 08:19   #11 (permalink)
Member: 975567
Thanks Meter: 7
Originally Posted by Advance-Box View Post
@ALL
B.R.
waiting for that !
see you in the phillipines
Old 09-03-2013, 09:28   #12 (permalink)
Member: 1003445
Thanks Meter: 3
hi,
this is the error i get
Interface Reset OK!
1.9-2.0V
ERROR: Connection Refused 0x04
does it means my eMMC is also dead?
Old 09-03-2013, 09:32   #13 (permalink)
Member: 651945
@white_beard
If you follow instructions 1:1 and removed resistor before TP, then most probably your
eMMC is also dead. I will put some BETA exe now which will show more logs on what
data was detected from the eMMC before you get the error 0x04.
0x04 means 4th step is bad,, but 1-2-3 is ok.
There are total 7 steps for eMMC initialize in ATF Software.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-03-2013, 09:58   #14 (permalink)
marvin62's Avatar
Member: 1147721
Sonork: 100.1624168
Thanks Meter: 13
so it cannot be done even atf jtag.
need to replace emmc..how to select phone model in jtag chain??
@white_beard
B.R.
Old 09-03-2013, 10:11   #15 (permalink)
Member: 1003445
Thanks Meter: 3
I did remove the resistor
probably my eMMC is faulty, cause sometimes i get this error
Interface Reset OK!
1.50-1.55V
and thanks for the fast reply
The Following 2 Users Say Thank You to white_beard For This Useful Post:
Page generated in 0.21622 seconds with 9 queries
