03-15-2015, 17:15 | #123 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | always stand here establishing emmc connection 0x0000000 ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 65646F4D204D4F524E4600010000 CSD : D02701320F5903FFFFFFFFE78A4040E3 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 134217728 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: 65 Device Type : Removable Card Application ID : 6F Product Name : M MORN Product Rev : 4.6 Product SN : 00010000 Manufactured : January 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 65646F4D204D4F524E4600010000_D616B705.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing 0x0014CA20 Blocks at 0x00000000 Partition Selected: USER AREA |
