07-10-2015, 06:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Lumia 540 DS WinPhone 8.1 Full Flashing !!! - FIRST IN THE WORLD Also check out other Lumia WinPhone 8.0/8.1/10 Phones Flashed by ATF: Microsoft Lumia 430 DS - Fully Tested Microsoft Lumia 435 DS - Fully Tested Nokia Lumia 520 - Fully Tested Nokia Lumia 530 - Fully Tested Nokia Lumia 620 - Fully Tested Nokia Lumia 625 - Fully Tested Nokia Lumia 630 - Fully Tested Nokia Lumia 638 - Fully Tested Nokia Lumia 640 XL - Fully Tested Nokia Lumia 720 - Fully Tested Nokia Lumia 735 DS - Fully Tested Nokia Lumia 810 - Fully Tested Nokia Lumia 820 - Fully Tested Nokia Lumia 822 - Fully Tested Microsoft Lumia 830 - Fully Tested Nokia Lumia 920 - Fully Tested Nokia Lumia 925 - Fully Tested Nokia Lumia 928 - Fully Tested Microsoft Lumia 929 - Fully Tested Microsoft Lumia 930 - Fully Tested Nokia Lumia 1020 - Fully Tested Nokia Lumia 1320 - Fully Tested Nokia Lumia 1520 - Fully Tested You Can Download Flash Files Here: http://forum.gsmhosting.com/vbb/f609...added-1660094/ Microsoft Lumia 540 DS WinPhone 8.1.1 Flashed Successfully with ATF Here are the Screenshot: Here is the Flashing Logs: Code: Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8/8.1/10 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ====================================================== ================================================ Basic Phone Information ================================================ SW Version : 02074.10000.15174.44001 IMEI Plain : 358613060299722 IMEI2 Plain : 358613060299730 Phone Type : RM-1140 HW Version : 3000 Product Code : 059X2H9 Basic Product Code: 059W9W9 Module Code : 0206689 PSN Number : 6488D87AB Operator Name : 000-PH Phone Version : BuildDate : Apr 23 2015 , BuildType : Release , HelloString : NCSd for WP8 , Version : 5.1 Manufacturer ID : RM-1140_1009 Security Mode : Restricted ================================================ Extended Phone Information ================================================ Public ID : 3CA285F8C4692D9148AF2B3E7C5BCCE47B2493BC Wireless Lan 0 ID: 30:0D:43:EE:26:CC Wireless Lan 1 ID: 30:0D:43:EE:26:CD Wireless Lan 2 ID: 30:0D:43:EE:26:CE Wireless Lan 3 ID: 30:0D:43:EE:26:CF Bluetooth ID : 30:0D:43:ED:8A:B6 ================================================ Simlock Information ================================================ SIMLOCK STATE : Not Locked Booting Flash Mode Initiated... Please wait upto 15 Seconds for HW Reset Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8212.P6247.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020225023C00 UEFI App: FLASH APP Flash App Protocol Version: 2.37 Flash App Implementation Version: 2.60 Query ROOT KEY HASH... ROOT_KEY_HASH: 86ACB97612E34C682490412CE98BAAD27779008E2189E5FB38665BBF1476EC98 Query PUBLIC ID... PUBLIC_ID: 3CA285F8C4692D9148AF2B3E7C5BCCE47B2493BC Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : 5690656F EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 98% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:06:59 FLASHING The Phone... BOOT Repair Tests will follow BR X-Shadow P.S. During the FLASH PROCESS, the phone WILL NOT DISPLAY ANY LOGO on the Screen. This is 100% Normal for newer Lumia phones with updated UEFI Apps... After Flashing, the phone will be totally BLACK SCREEN for about 1-3 minutes... Just relax, this is perfectly Normal for newer LUMIA Phones. DO NOT INTERFERE with the phone's INITIAL BOOT!!! |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
