11-09-2012, 11:21 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,111 | Nokia x1-01 rm-713 Problem Was'' Dial / Received / Miss Call Not Showing Than I Doing Flash But No Luck Any Body Know About This Problem For Infineon CPU Proper Solution. Here Flash Log:- Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: E:\Nokia\SarasSoft\Products\RM-713\rm713_007.500 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: 55FD Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: AA06 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: C1B9 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: E:\Nokia\SarasSoft\Products\RM-713\rm713_007.50ms PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x005B0B7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4918144 bytes Data Checksum: 01ED Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: E:\Nokia\SarasSoft\Products\RM-713\rm7130_nai07.50ms CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F0CAFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 707328 bytes Data Checksum: F4D3 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:20 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.50 29-11-11 RM-713 (c) Nokia IMEI: 357893040037829 Product Serial Number: 268184BAH Product Code : 059D908 Module Code : 0204727 Basic Production Code: 059K2G8 PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MS ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nms MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BARACOAv82 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune Here Self test Log:- Code: MCU: V 07.50 29-11-11 RM-713 (c) Nokia IMEI: 357893040037829 Product Serial Number: 268184BAH Product Code : 059D908 Module Code : 0204727 Basic Production Code: 059K2G8 PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MS ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nms MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BARACOAv82 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED MCU: V 07.50 29-11-11 RM-713 (c) Nokia IMEI: 357893040037829 Product Serial Number: 268184BAH Product Code : 059D908 Module Code : 0204727 Basic Production Code: 059K2G8 PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MS ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nms MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BARACOAv82 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED SELFT TEST Start.... SELFT TEST Done.... |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
03-13-2013, 14:24 | #3 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | Nokia x1-01 rm-713 Problem Was'' Dial / Received / Miss Call Not Showing This water demage clen off all ic and slow hetup......... |
03-14-2013, 08:32 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Palash It is a hardware fault , Not solve by flashing . Replace the diode near crystal Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
