Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-10-2015, 13:04   #46 (permalink)
mbahjo's Avatar
Member: 1329173
Thanks Meter: 106
tengkyu brader problem solved downgrade Atf 11.80
Old 05-23-2015, 16:49   #47 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
nokia X2 RM-1013 flashing done with atf box
Nokia X2 RM 1013 Phone Dual Sim
manually install/update your Nokia X2 Drivers to Nokia Emergency Connectivity Drivers which you can find here:
C:\AdvanceBox Turbo Flasher\Drivers\
http://174.120.45.27/tmp/EmergencyDownloadDriver.msi
You will find a file EmergencyDownloadDriver.msi
Install That.
After your Phone is detected in Device Manager as "Nokia Emergency Connectivity"
Old 06-24-2015, 06:23   #48 (permalink)
dvd_anwar's Avatar
Member: 896667
Sonork: 100.1586139
Thanks Meter: 1,596
x2 rm-1013 driver problem win7???
no need EmergencyDownloadDriver.msi just NokiaCareConnectivity.inf select http://forum.gsmhosting.com/vbb/10719519-post26.html 100% working tested by me
Old 06-27-2015, 19:48   #49 (permalink)
Member: 833456
Thanks Meter: 4
Nokia x2 model 1013 rm -1013 buzzer not working but speaker working fine...plz any one healp me..
Old 07-08-2015, 14:08   #50 (permalink)
Member: 2274452
nokia X2-RM1013 connect Qualcomm 9008 not solution chang to Nokia Emergency Connectivity, maybe eMMC pabelm
Old 08-20-2015, 06:26   #51 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
First install atuo install nokia emergency drivers.after that select nokia from decive is and update drivers that is....
Old 11-10-2015, 18:00   #52 (permalink)
hassan1975's Avatar
Member: 28819
Thanks Meter: 222
Originally Posted by Advance-Box View Post
@TX101
The easiest way to fix you problem is to manually install/update your Nokia X2 Drivers to Nokia Emergency Connectivity Drivers which you can find here:
Install That.
Then you can flash it easily
Also, you can download Drivers here in case you cannot find it:
it is work on windows 7 ?????????????
Old 11-15-2015, 15:03   #53 (permalink)
Member: 58081
Thanks Meter: 10
i did all but its still not active
Old 11-22-2015, 18:21   #54 (permalink)
Member: 329994
Thanks Meter: 14
Originally Posted by kabul View Post
1-connect phone pc go to device manager open com ports
uninstall (USB diagnostics 9008)
2-disconnect or connect phone pc open update drivers software tab
3-browse my computer for driver software
4-let me pick from a list of device drivers on my computer
5-select Nokia usb drivers
6-Agen flash success
solved my problem with ATF
This is a on phone,not in qhusb-bulk,LOL
Old 12-05-2015, 06:31   #55 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
Phone in Qhusb_bulk mode
problem is emergency driver not installing..i am on windows 7 should i use win xp ?
Old 12-10-2015, 11:49   #56 (permalink)
Member: 1273573
Sonork: 100.1623251 QQ.2905713135
Thanks Meter: 3,780
Solve My Problem With ATF
Nokia X2 Dead Boot Repair Done
Good Report.. MR.Kabul
Guide Setup By Setup Deteils 100% warking Solution
Nokia Android Phone Flashing Started
           Nokia Android Firmware Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Press and Hold the VOLUME DOWN button
  2. Connect it to the USB Port while still Pressing
  3. Continue to Press the VOLUME DOWN button for 15
     more seconds
Emergency Loader Found!
Sending FireHose Loader...
Starting FireHose Loader...
FireHose Loader Accepted!
Start Sending Files...
BOOT Partition Write: rm1013_2.1.0.13_user_boot.img
Partition Write OK!
CACHE Partition Write: rm1013_2.1.0.13_user_cache_1.img
Partition Write OK!
ABOOT Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn
Partition Write OK!
ABOOTBAK Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn
Partition Write OK!
MISC Partition Write: rm1013_2.1.0.13_user_misc_erase.img
Partition Write OK!
MODEM Partition Write: rm1013_2.1.0.13_user_NON-HLOS.bin
Partition Write OK!
RECOVERY Partition Write: rm1013_2.1.0.13_user_recovery.img
Partition Write OK!
RPM Partition Write: rm1013_2.1.0.13_user_rpm.mbn
Partition Write OK!
RPMBAK Partition Write: rm1013_2.1.0.13_user_rpm.mbn
Partition Write OK!
SBL1 Partition Write: rm1013_2.1.0.13_user_sbl1.mbn
Partition Write OK!
SBL1BAK Partition Write: rm1013_2.1.0.13_user_sbl1.mbn
Partition Write OK!
SDI Partition Write: rm1013_2.1.0.13_user_sdi.mbn
Partition Write OK!
TZ Partition Write: rm1013_2.1.0.13_user_tz.mbn
Partition Write OK!
TZBAK Partition Write: rm1013_2.1.0.13_user_tz.mbn
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_1.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_10.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_11.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_2.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_3.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_4.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_5.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_6.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_7.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_8.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.13_user_system_9.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_1.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_2.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_3.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_4.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_5.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_6.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_7.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_8.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_1.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_10.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_11.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_12.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_13.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_14.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_15.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_16.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_17.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_18.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_19.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_2.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_20.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_21.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_22.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_23.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_24.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_3.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_4.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_5.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_6.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_7.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_8.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_9.img
Partition Write OK!
Sending All Files Done!
Total Flashing Time (Erase + Flashing) : 00:03:16
Restarting Phone...
Wait 1 to 3 Minutes for Phone First Boot
BR..
JAMIL MOBILE
The Following User Says Thank You to zulfqarali For This Useful Post:
Old 12-18-2015, 08:35   #57 (permalink)
Member: 2285601
Thanks Meter: 13
best dongle done dead x2-rm-1013....run
Old 12-18-2015, 08:37   #58 (permalink)
Member: 2285601
Thanks Meter: 13
no need extra driver use atf driver.....
Old 01-19-2016, 21:36   #59 (permalink)
alyasjee's Avatar
Member: 1739869
Thanks Meter: 10
Sir on windows 10 i have tried all these tips but not working...can you help by teamviewer ?
Old 02-16-2016, 14:11   #60 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
@TX101
Install That.
flashing done but phone still dead and detect as nokia emergency conterverty
more seconds
BOOT Partition Write: rm1013_2.1.0.12_user_boot.img
Partition Write OK!
CACHE Partition Write: rm1013_2.1.0.12_user_cache_1.img
Partition Write OK!
ABOOT Partition Write: rm1013_2.1.0.12_user_emmc_appsboot.mbn
Partition Write OK!
ABOOTBAK Partition Write: rm1013_2.1.0.12_user_emmc_appsboot.mbn
Partition Write OK!
MISC Partition Write: rm1013_2.1.0.12_user_misc_erase.img
Partition Write OK!
MODEM Partition Write: rm1013_2.1.0.12_user_NON-HLOS.bin
Partition Write OK!
RECOVERY Partition Write: rm1013_2.1.0.12_user_recovery.img
Partition Write OK!
RPM Partition Write: rm1013_2.1.0.12_user_rpm.mbn
Partition Write OK!
RPMBAK Partition Write: rm1013_2.1.0.12_user_rpm.mbn
Partition Write OK!
SBL1 Partition Write: rm1013_2.1.0.12_user_sbl1.mbn
Partition Write OK!
SBL1BAK Partition Write: rm1013_2.1.0.12_user_sbl1.mbn
Partition Write OK!
SDI Partition Write: rm1013_2.1.0.12_user_sdi.mbn
Partition Write OK!
TZ Partition Write: rm1013_2.1.0.12_user_tz.mbn
Partition Write OK!
TZBAK Partition Write: rm1013_2.1.0.12_user_tz.mbn
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_1.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_10.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_11.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_2.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_3.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_4.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_5.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_6.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_7.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_8.img
Partition Write OK!
SYSTEM Partition Write: rm1013_2.1.0.12_user_system_9.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_1.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_2.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_3.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_4.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_5.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_6.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_7.img
Partition Write OK!
CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_8.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_1.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_10.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_11.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_12.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_13.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_14.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_15.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_16.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_17.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_18.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_19.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_2.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_20.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_21.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_22.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_23.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_24.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_3.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_4.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_5.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_6.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_7.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_8.img
Partition Write OK!
USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_9.img
Partition Write OK!
Total Flashing Time (Erase + Flashing) : 00:05:17
Restarting Phone...
The Following User Says Thank You to diesel6 For This Useful Post:
Page generated in 0.20651 seconds with 9 queries
