05-23-2015, 16:49 | #47 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Tunisia
Member: 520537 Status: Offline Thanks Meter: 230 | nokia X2 RM-1013 flashing done with atf box Nokia X2 RM 1013 Phone Dual Sim manually install/update your Nokia X2 Drivers to Nokia Emergency Connectivity Drivers which you can find here: C:\AdvanceBox Turbo Flasher\Drivers\ http://174.120.45.27/tmp/EmergencyDownloadDriver.msi You will find a file EmergencyDownloadDriver.msi Install That. After your Phone is detected in Device Manager as "Nokia Emergency Connectivity" |
06-24-2015, 06:23 | #48 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Anwar Telecom .DHAKA Age: 38
Member: 896667 Status: Offline Sonork: 100.1586139 Thanks Meter: 1,596 | x2 rm-1013 driver problem win7??? no need EmergencyDownloadDriver.msi just NokiaCareConnectivity.inf select http://forum.gsmhosting.com/vbb/10719519-post26.html 100% working tested by me |
08-20-2015, 06:26 | #51 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | First install atuo install nokia emergency drivers.after that select nokia from decive is and update drivers that is.... |
11-10-2015, 18:00 | #52 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | Quote:
11-22-2015, 18:21 | #54 (permalink) | |
Insane Poster Join Date: Aug 2006 Location: Pakistan,Bahawalpur
Member: 329994 Status: Offline Thanks Meter: 14 | Quote:
12-10-2015, 11:49 | #56 (permalink) | |
Banned Join Date: Mar 2010 Location: Okara Pakistan Age: 47
Member: 1273573 Status: Offline Sonork: 100.1623251 QQ.2905713135 Thanks Meter: 3,780 | Quote:
Solve My Problem With ATF Nokia X2 Dead Boot Repair Done Good Report.. MR.Kabul & Guide Setup By Setup Deteils 100% warking Solution Code: Nokia Android Phone Flashing Started ====================================================== Nokia Android Firmware Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ====================================================== Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.13_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.13_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.13_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.13_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.13_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.13_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:03:16 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot ............................... BR.. JAMIL MOBILE ............................. | |
The Following User Says Thank You to zulfqarali For This Useful Post: |
02-16-2016, 14:11 | #60 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Quote:
Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.12_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.12_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.12_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.12_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.12_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.12_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.12_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.12_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.12_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.12_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.12_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.12_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.12_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.12_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.12_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.12_059V781_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.12_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:05:17 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot | |
The Following User Says Thank You to diesel6 For This Useful Post: |
