02-13-2015, 06:51 | #31 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | http://bb5tool.com/download/index-1...._MTKx_Asha.rar |
02-14-2015, 00:27 | #33 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1595075 Status: Offline Sonork: 085264774708 Thanks Meter: 1 | is already instaler why not sunning in my box sir[ Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Emergency Loader Found! Sending FireHose Loader... |
02-17-2015, 16:30 | #38 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Check HERE and learn one thing. Do you know what you will learn? Always act like them sometime. You still confused? Well am not, when I look well there. What I did when I had that kind problem is to act like them by making sure that I used the same version that did that successful. So all I mean is, uninstall your ATF 11.92 and install ATF 11.80 and it will work for you because that is what I did and mine that has same problem like yours worked. Is like the latest version of ATF 11.92 has bug on that. Below is my 2 logs; unsuccessful with ATF 11.92; Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Emergency Loader Found! Sending FireHose Loader... Successful with lower ATF 11.80 log; Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.13_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.13_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.13_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.13_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.13_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.13_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:03:46 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot So always learn from what they do ! |
04-05-2015, 12:26 | #41 (permalink) | |
No Life Poster Join Date: Oct 2006 Age: 45
Member: 369678 Status: Offline Thanks Meter: 192 | Use atf 11.80 for nokia x2 rm-1013 Quote:
04-24-2015, 18:14 | #45 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: Kumasi-Ghana
Member: 1608526 Status: Offline Sonork: 100.1611913 Thanks Meter: 60 | Quote:
plz boss my phone is in Qualcomm hs usb mode only plz do u have jtag boot repair support cos i can repair boot i have done for nokia xl....etc | |
