11-26-2014, 11:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 330960 Status: Offline Thanks Meter: 54 | Nokia X2 RM-1013 died with ATF big box.... - [NICE SOLUTION INSIDE] I've a new set nokia x2 rm-1013 and want to update to new OS.I up the os with ATF 11.80 and program only stop at: " 14:50:45 : Nokia Android Firmware Flasher 14:50:45 : ================================================== ==== 14:50:45 : 14:50:45 : If the Phone is ALIVE 14:50:45 : 1. Power On the Phone and Connect it to the USB Port 14:50:45 : 14:50:45 : If the Phone is DEAD 14:50:45 : 1. Press and Hold the VOLUME DOWN button 14:50:45 : 2. Connect it to the USB Port while still Pressing 14:50:45 : the VOLUME DOWN button 14:50:45 : 3. Continue to Press the VOLUME DOWN button for 15 14:50:45 : more seconds 14:50:45 : ================================================== ==== 14:50:45 : 14:50:47 : Waiting for USB Cycle... 14:50:47 : USB Cycle OK! " After that, the phone is now completely bricked. It cannot power on, removing and inserting the battery does not work. It will not enter download mode again, either. If plugged into USB, the phone does not power on nor display any charging animation. However, checking shows that there is a QHSUSB device. Can ATF Team and Anyone can help? I would be very gratefull.Thanks you |
11-26-2014, 12:21 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @yentrang120705 You are doing the right thing. Just install the correct Drivers, which you can find here: C:\AdvanceBox Turbo Flasher\Driver You will find Nokia X2 Drivers there... Once you install the drivers, and the phone is already detected as Nokia Emergency Device , then you can flash the phone again with ATF. If you cannot find the X2 Drivers in that folder, then you MUST make FULL 11.80 Install so that everything will be 100% OK. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
11-26-2014, 13:06 | #5 (permalink) | |
Member: 330960 Status: Offline Thanks Meter: 54 | Quote:
The Following User Says Thank You to yentrang120705 For This Useful Post: |
11-26-2014, 22:18 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @TX101 The easiest way to fix you problem is to manually install/update your Nokia X2 Drivers to Nokia Emergency Connectivity Drivers which you can find here: C:\AdvanceBox Turbo Flasher\Drivers\ You will find a file EmergencyDownloadDriver.msi Install That. After your Phone is detected in Device Manager as "Nokia Emergency Connectivity" Then you can flash it easily Also, you can download Drivers here in case you cannot find it: http://174.120.45.27/tmp/EmergencyDownloadDriver.msi |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
11-27-2014, 05:41 | #9 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
Just remove battery,put it again. (confirm its fully charged, or use a new working battery) Better install drivers manually [C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\MANUAL_INSTALL] Restart System. Do job again. Report here with full log or picture. | |
11-28-2014, 03:03 | #12 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Solution is already posted here: http://forum.gsmhosting.com/vbb/10702400-post7.html POST # 7 Please OPEN YOUR EYES BRO. | |
11-28-2014, 03:15 | #13 (permalink) | |
