05-24-2014, 06:10 | #1 (permalink) | |
Insane Poster Join Date: Mar 2008 Location: IRAN
Member: 723657 Status: Offline Sonork: 100.1583371 Thanks Meter: 41 | Successfully Boot Repaired Phones via ATF JTAG Nokia X RM-980 repair boot Done Tanks ATF Team Quote:
The Following 2 Users Say Thank You to masih455 For This Useful Post: |
06-24-2014, 11:06 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Successfully Boot Repaired Phones via ATF JTAG Greetings! Please put in this thread all successfully boot repaired phones via ATF JTAG. Nokia Lumia / Nokia Android / Samsung / Cherry Mobiles and others.... Do not make new threads in our section, just put all log/screenshot in this sticky thread. All other posts that are NOT related to this topic will be deleted... BR |
The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post: |
06-24-2014, 11:11 | #3 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Samsung GT-I8262 Boot Repaired with ATFJTAG - Repairing Boot with ATFJ.exe v1.0.8: - Boot Repaired successfully, Download Mode - VOL DOWN + HOME + POWER: - Flashing with Odin3: - Profit |
The Following 7 Users Say Thank You to ..::Angel::.. For This Useful Post: |
07-03-2014, 08:43 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Nokia Lumia 1320 boot repair Success !! Nokia Lumia 1320 boot repair Success !! Produce :- Jtag Pinouts Dismantle phone Solder Wires Boot repair Start Successfully Boot repair Phone Flashing Flashing Completed Big Thanks to Atf team |
The Following 7 Users Say Thank You to .::AZEEM::. For This Useful Post: |
07-04-2014, 12:34 | #7 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | NOKIA X REPAIR BOOT DONE Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Samsung S5XKMB, 3.64 GiB Testing Device Memory...OK Sending Flash Loader...OK (91418 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== Completed in 0h 2m 24s. Code Download Speed 376 KiB/sec. |
07-07-2014, 18:14 | #9 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | SGH-T999 boot repair done with atfj.exe Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x707910E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Toshiba 016G92, 14.68 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== ========== now fone is download mode ok with the help of great atf team. |
The Following 3 Users Say Thank You to rajesh_ch For This Useful Post: |
07-12-2014, 11:48 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | I9300 Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF1565A633B CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : 565A633B Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF1565A633B_23E5AE68.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Write EXT_CSD Backup Task Done! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:04 Write Success! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:04 Write Success! Start Writing 0x001EC209 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:29:17 Write Success! |
The Following User Says Thank You to mobilegsm30 For This Useful Post: |
08-07-2014, 12:30 | #14 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | samsung i8150 stuck on logo repair done with ATF Jtag |
The Following User Says Thank You to hm.faizan For This Useful Post: |
