07-04-2016, 23:41 | #16 (permalink) | |
Junior Member Join Date: May 2005 Location: venezuela Age: 46
Member: 148106 Status: Offline Thanks Meter: 2 | Quote:
-Uninstall with "Revo Unistaller" -delete atf folder in root directory in c:// -reboot pc -install v12.60 -reboot pc -connect box and install drivers manually from C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS (i use ftdibus.inf) -open v12.60 and install drivers shenzhen -reboot pc -update firmware -> (query result - not found) machine whitout AV - use rear ports directly from mother board | |
07-05-2016, 09:58 | #17 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok, drivers seem all ok, only need of see directly what is wrong....not for last this Box can have issue....but want to do one try...(only for this time, clear for all), contact me in my Skype, (loock my profile), sending Add request with the reason ...otherwise Not accept you...too much spammers ask of to be added... BR |
The Following User Says Thank You to allumts For This Useful Post: |
07-06-2016, 15:52 | #18 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Never can working, ATF NET 49 credits was Faulting....so when have same problem above after tryed my procedure and tryed in all mode, all you know of ceck you "ATF NET" Credits, must be 49 credits showing for use and Update Firmware!!!! Quote:
Br allumts | |
01-07-2017, 01:05 | #24 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | ok and what about this Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021216 Library Version : 00030211 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : E1C5F6309EFF65D39675AD7A Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done i try restore firmware and update same thing Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: Advance-Box - GSM-Forum |
01-07-2017, 03:51 | #25 (permalink) | |
Junior Member Join Date: Nov 2016
Member: 2650380 Status: Offline Thanks Meter: 0 | Quote:
01-07-2017, 11:00 | #26 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Can post here Name of this reseller???? IMPORTANT: When buy ATF also in trusted site like "Amazon", loock carefully what Model you are purchasing, old Big Atf Yellow coming W/O any Activaction, must need of buy "ATF NET" (49 credits), for Active this. Atf Nitro/Light coming with ATF NET incluse ATF GOLD coming with ATF NET and JTAG Active. So, contact you reseller and ask for Refund or for "ATF NET" Activaction. Br allumts | ||
01-07-2017, 13:23 | #27 (permalink) | |
Member: 205475 Status: Offline Thanks Meter: 179 | thanx Quote:
Reseller: gsm-surces it was working well | |
01-07-2017, 13:45 | #28 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | I cannot know what have done you reseller, but if first was working good, it's very clear: Quote:
