10-17-2015, 00:11 | #17 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1813092 Status: Offline Sonork: bentaouit Thanks Meter: 1 | this is work for me: https://www.youtube.com/watch?v=nhKcRRcoh3o |
10-17-2015, 02:40 | #18 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Quote:
10-27-2015, 07:08 | #20 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Copenhagen, Denmark Age: 59
Member: 51434 Status: Offline Thanks Meter: 16 | Fake... Read: iPhone 6 / 6+ The serial chip is stored on the touch ID button itself. There is no chip on the flex, only passiv components. |
The Following User Says Thank You to Henrik Liss For This Useful Post: |
11-05-2015, 20:26 | #27 (permalink) |
Insane Poster Join Date: May 2005 Age: 46
Member: 149217 Status: Offline Thanks Meter: 21 | 100 % Solution Error 53 Step 1. Disconnect all lcd, touch , headphone etc .. Step 2. Only conetar the Home button and connect it to iTunes and restore IOS with the latest version . I Ami worked perfectly . |
The Following User Says Thank You to c3llf3r For This Useful Post: |
11-23-2015, 15:37 | #29 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | Maybe this here will some things make a little bit clearer for you. The Problem with Error 53 is that the circuit in the fingerprint sensor is married with the CPU. If you try to install a new Firmware the Data in beginning of the process will stored in the memory (progress bar runs till appr.70%). After this normaly the Baseband will be written (progress bar appr. 70% to 100%) But after the Data is written in the memory the cpu will check if the installation is successfully done and then he starts a communication with the fingerprint sensor. If this communication is failed then Error 53 appears and all stopped. So you must be sure that you have the original LCD and the original fingerprint sensor! No other solution is possible at this time! The communication between CPU and fingerprint sensor runs in a serial communication way.. So yo must know wich data goes from CPU to Sensor and wich answer from Sensor is expected from CPU. This is very difficult to make this protocol visible and understandable. Only APPLE can help in a way that they will change the installation routine. But i think they will never do this. Best for Apple is to sell new phones they think Last edited by it-repair; 11-23-2015 at 15:40. Reason: edit |
The Following 3 Users Say Thank You to it-repair For This Useful Post: |
