10-28-2020, 21:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,089 | iPad pro 9,7 gsm to wifi no wifi ! any help ? by theway the trick didn't work to bypass icloud |
The Following User Says Thank You to jawad8305 For This Useful Post: |
12-28-2020, 22:54 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: CANADA
Member: 292789 Status: Offline Thanks Meter: 637 | your ipad pro 9.7 is activated ? from cellular to wifi you must need to replace wifi ic but right now issue is ipad not activating with in SN wifi bt info |
12-29-2020, 12:51 | #6 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,089 | here's the situation ,ipad is cellular and i converted it to wifi ,now after bypass wifi not working (greyed out),pasha4ur posted on his website that wifi drivers are needed to fix it can any one help in that matter ? |
12-29-2020, 14:24 | #7 (permalink) | |
Member: 292789 Status: Offline Thanks Meter: 637 | Quote:
Tell me one thing your ipad in open menu right now ? | |
12-31-2020, 02:42 | #8 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2796406 Status: Offline Thanks Meter: 2 | back when pascha4ur wrote these guides, the ipads had seperate iPSW for wifi and cellular models respectively. So you had to extract the wifi drivers of the iPSW for cellular version and replace them inside the iPSW for wifi version. Now that all ipad versions share the same iPSW i think you would have to rename the drivers for the wifi-only ipad. But i dont even know if it still works. I also read somewhere on thiss board that you can jailbreak and manually insert the correct drivers into the filesystem, but i cannot confirm that |
01-02-2021, 21:35 | #9 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,089 | I can access system files the ipad is jailbroken,i need paths for the files which should be renamed,if the files can be extracted and pasted into the ipad will be good,someone explain how plz |
01-03-2021, 19:32 | #10 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: Toronto Canada
Member: 1599578 Status: Offline Sonork: 8114214 Thanks Meter: 131 | Quote:
which SN WIFi BT info you used ? | |
01-05-2021, 17:44 | #13 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | After ios 13 or 14, icloud got locked by serial number instead of udid so, if you do this trick on any ios 13 or 14 idevice (can't recall but its been some time so its probably since ios 13), you still get locked device. When this trick worked, wifi devices got locked by udid. As soon you change device ID, udid changed and gsm that were locked by SN, got unlocked because wifi dev were locked by UDID. On IOS 13, apple changed the rules on the SN/udid dev lock. Hence the need to do the sn/wifi/bt/etc programing. In this case also replace the wifi ic or, if you can, the wifi drivers. |
The Following User Says Thank You to Desirat For This Useful Post: |
01-07-2021, 22:35 | #14 (permalink) | |
Junior Member Join Date: Apr 2006
Member: 265151 Status: Offline Thanks Meter: 1 | Quote:
2)but on cellular 13, 14 ios devices you must also replace wifi ic. After resistor mod. Final question if iPad activated (after mod/ serial) in ios 11, then updated to 13 and full reset will it activate again with no problems since server accepted once before? A) for cellular device? B) for wifi device? Am I understanding correctly Many thanks Sent from my SM-G950F using Tapatalk | |
