Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-03-2010, 12:38   #1 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: 100.1593148
iphone 4 battery connector
i have un iphone with damaged connector
please can you check if pins of connector (blue arrow) are connected with gold points (red arrow) ? and where connect others 2 pins?
br
Old 11-04-2010, 07:30   #2 (permalink)
chip_2000's Avatar
Member: 22400
My solutions. welcome.
The Following 4 Users Say Thank You to chip_2000 For This Useful Post:
Old 11-04-2010, 08:36   #3 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: 100.1593148
bro you know also alternative point for green and blue?
thank so much
Old 11-04-2010, 08:49   #4 (permalink)
chip_2000's Avatar
Member: 22400
thank so much
sorry no. I check pcb but not found.
Old 11-04-2010, 08:59   #5 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
br
sure as you seeing the in front of ground point nothing and B+ point have a dot on it's track you can also connect center two points with these golden dots.
Good Luck
The Following User Says Thank You to >>PakFones<< For This Useful Post:
Old 11-04-2010, 20:47   #6 (permalink)
fr3nsis's Avatar
Member: 190882
Sonork: 100.1593148
Good Luck
sorry i dont understand...can do a schematic?
The Following User Says Thank You to fr3nsis For This Useful Post:
Old 04-02-2011, 15:27   #7 (permalink)
Member: 83984
ı facing same problem. ı need battery connector diagram
Old 04-29-2011, 15:26   #8 (permalink)
Member: 1387214
Middle pins are connected in two different points of logic board, it's very hard to wiring these..
Old 04-29-2011, 15:39   #9 (permalink)
JASKY007's Avatar
Member: 1125280
thanks.............................
Old 04-30-2011, 07:18   #10 (permalink)
Member: 295624
br
iphone 4 battery connector ways........
The Following 3 Users Say Thank You to sem_g For This Useful Post:
Old 04-30-2011, 07:40   #11 (permalink)
chip_2000's Avatar
Member: 22400
Originally Posted by sem_g View Post
Photoshoper? Edit my picture? ha ha...
Old 04-30-2011, 10:49   #12 (permalink)
GSMan's Avatar
Member: 1675
Solution Battery connector
Really the 2 center points it's very hard to found spend an hour for me to found and its very importand .Make the jumper from connector to these points not from test points to FL5 and FL7 and becarefull the point of ground at 2 capacitors close to them.At photo to ignore better the point i have marked at the other (not the correct) side of FL5-FL7 but doesn't matter if you connect there only by bypass these 2 parts but if you can cut the metal and sold at correct points.
Best Regards
GabiRo
P.S. if you have missing the Negative Temp Control signal (Green mark point) the phone restarts after 3-5 min and don't charge correctly but very very slowly (2hours for 10%)
The Following 5 Users Say Thank You to GSMan For This Useful Post:
Old 04-30-2011, 19:35   #13 (permalink)
Member: 1508411
That'S it, I've been looking for an alternative spot for the yellow pin and now i have it. Great. It's easier to connect to than it looks. Cut away the cage around the corner and then you'll see a tiny eyelet hole that goes through the board. feed a little wire through the hole and it holds the wire in place so you can just use a pin head worth of liquid wire glue to connect, nice and neat
The Following User Says Thank You to Hobson For This Useful Post:
Old 05-02-2011, 11:45   #14 (permalink)
Member: 1508411
To clarify. you are connecting to the first and last of the bank of capacitors from the above photo.
The Following 7 Users Say Thank You to Hobson For This Useful Post:
Old 05-03-2011, 08:27   #15 (permalink)
Member: 1508411
OK, I can confirm this works, It's a fiddly job and you need a stereo microscope to perform the connections.But it works! 100%. battery now charging fully again.
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 08-09-2010 10:20
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.41538 seconds with 12 queries
