06-18-2011, 22:59 | #31 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1553972 Status: Offline Thanks Meter: 0 | i had to re-solder the battery connector back on but did not solder the 2 points on the other end, phone seems to be rebooting once or twice a day would it be because these 2 points? |
06-20-2011, 07:29 | #32 (permalink) | |
Freak Poster Join Date: Jul 2000 Location: GabiRo
Member: 1675 Status: Offline Thanks Meter: 44 | Quote:
Do it and stoping rebboot BR GabiRo | |
06-22-2011, 01:53 | #33 (permalink) | |
Junior Member Join Date: Feb 2009 Location: Houston, Tx USA
Member: 981200 Status: Offline Thanks Meter: 3 | Quote:
06-24-2011, 14:03 | #34 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Galway, Ireland
Member: 1508411 Status: Offline Thanks Meter: 36 | you can ignore those two pins, I never used them when i did it. I think they were just Grounded. maybe someone can confirm this or if i remember i can check this evening. |
06-25-2011, 17:55 | #35 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 240946 Status: Offline Thanks Meter: 10 | my battery connector was soldered back on but the phone now restarts itself constantly is it the 2nd connecter from the bottom (earth) that needs re soldered? The 3rd from bottom (2nd from top) |
06-26-2011, 22:19 | #36 (permalink) | |
BR | |
The Following User Says Thank You to GSMan For This Useful Post: |
06-30-2011, 17:42 | #38 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1607043 Status: Offline Thanks Meter: 0 | Help! Slight problem one of the surface mount resistor/capacitors next to the pad has lifted anyone know the value and a better place for mounting it? Last edited by lemon1; 06-30-2011 at 17:49. |
08-13-2011, 00:25 | #39 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1632195 Status: Offline Thanks Meter: 0 | Ok I've re soldered the battery connector on the board. I'm getting current to the test locations. But I,m unable to get the phone to turn on with the battery. It will go into the please connect to iTunes mode when I use external power. Any ideas? |
09-14-2011, 11:27 | #41 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1611246 Status: Offline Thanks Meter: 0 | Thank you guys. I'v solved this problem now. I soldered on the left side and all went well. Thanks!!!! cut the metal it's easy you only need a pinze and you dont have to force it. |
09-14-2011, 18:36 | #42 (permalink) |
Insane Poster Join Date: Feb 2011
Member: 1515083 Status: Offline Thanks Meter: 2 | I am thinking of replacing the battery in my iPhone4. What exactly is the problem with removing the battery connector and how does one remove it properly to avoid going through these surgical repairs ? |
09-14-2011, 22:16 | #43 (permalink) |
Member: 1611246 Status: Offline Thanks Meter: 0 | Hi!! You only have to do carefully...maybe hold the connector soldered to the mainboard down with a small screwdriver while you are taking up the metal on the battery connector |
09-17-2011, 16:23 | #44 (permalink) |
Major Poster Join Date: Jul 2011 Location: MONTERREY MEXICO
Member: 1623138 Status: Offline Thanks Meter: 6 | hi i have a problem whit the pads #1 and #4 i have continuos and the positive pad is ground some body know what is the problem on this board previous i resolder the complete conector thanks! |
09-24-2011, 04:19 | #45 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1655145 Status: Offline Thanks Meter: 1 | Mine is broken too. I've read all 4 pages but still has some doubts. I am not an expert in eletronics so I may have some basic doubts. It broke when I removed the battery and I tried to sold it myself. I did not know if I broke something. After I sold it, it did not work. I sent it to an iphone repair store and they've said that the logic board is damaged and wanted to charge me U$400 to replace it but I've seen some boards that are worser then mine. Is there a way to damage the board solding it ? It is not turning on (so this means that the battery is not connected?) and when I plug it it turn on, it turns on and restart after a few minutes. But when it is on, it says only emergency calls and if I click in the "i", it says "IMEI: UNKNOW" and "ICCID: Unknow". There are some gold dots near the connector. I maybe have damaged it. Are they important ? Can they've damaged the logic board ? Also there is a picture of the connector to see how damaged they are. I do have a meter. How do I check wich connector (A, B, C, D) is not working ? |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
