09-30-2011, 18:53 | #64 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1611246 Status: Offline Thanks Meter: 0 | is the battery charged?? you didnt answer me before... what was the % of charge the last time u used it? maybe the battery is dead...when you plug the phone with the battery connetted what do you see? does the phone recognize the battery? or it show 100% charged with the plug symbol? |
09-30-2011, 19:19 | #65 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1664192 Status: Offline Thanks Meter: 0 | I have another iphone that works perfectly well. I took the battery charged at 64% to place it in the iphone defective. I get the same result as cadumg83. The iPhone acts as if there was no battery. |
09-30-2011, 19:31 | #66 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
Then check on damaged if each track arrives to destination "Battery Connector". | |
09-30-2011, 19:35 | #67 (permalink) | |
Member: 1611246 Status: Offline Thanks Meter: 0 | Quote:
my iphone was in worse condition than yours... and now it still works... you wont short circuit by trying | |
09-30-2011, 22:44 | #68 (permalink) |
Member: 1664192 Status: Offline Thanks Meter: 0 | Wites : I measured the value that I find when I connect the different pins with the metal framework for the ihone works: pin 1 to metal framework : 0.3 pin 2 to metal framework : 1 pin 3 to metal framework : 1 pin 4 to metal framework : 1 With the iphone defective : pin 1 to metal framework : 0.3 pin 2 to metal framework : 0.3 pin 3 to metal framework : 1 pin 4 to metal framework : 0.3 filiking : I did what you advised me to do but unfortunately it does change nothing. I unsolder the battery connector and I was surprised to see that the pin 4 is always connected to the metal framework while I removed all the solder : not compressed : http://imageshack.us/photo/my-images/51/img1181oo.jpg/ PS : thank you so much for your help |
10-01-2011, 10:27 | #69 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | That mean Vbat+ & Gas Gauge is shorting to GND this is not good you need to find where is shorting,to find Vbat+ where shorting give externally 3Volts to Vbat+ & GND and check what is heating,where is heating there is short. |
10-01-2011, 21:14 | #72 (permalink) |
Member: 1664192 Status: Offline Thanks Meter: 0 | Thanks for your shematic. To put the 3 + volts between Vbat and GND, which one is the +? I tried with Vbat + as a pole + the wires of my external battery 3V and the GND are immediately very hot... You say "check 2 black filters for continuity". What is black ? The small capacitors ? |
10-01-2011, 22:13 | #73 (permalink) | |
Check filters with yellow dots marked. You say battery is getting hot then problem is there on flex where you removed connector.Check with your lips maybe something else is heating on the flex. Remember connect properly + of battery to Vbat + on flex. | |
10-01-2011, 23:04 | #74 (permalink) | |
Member: 1664192 Status: Offline Thanks Meter: 0 | Quote:
What do you call "flex" and "filter" ? | |
10-02-2011, 09:40 | #75 (permalink) | |
battery connector entirely your problem will solve. I can't call that board but is some kind of board made of flex it mean flexible. | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
