07-13-2018, 03:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 310423 Status: Offline Thanks Meter: 18 | IPhone 6 Plus dead after replacing touch ic |
07-13-2018, 05:20 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You can measure everything arround and find it own, but you can wait - will make picture solution to our facebook page... |
07-13-2018, 15:33 | #5 (permalink) | |
Insane Poster Join Date: Apr 2016 Location: india
Member: 2562692 Status: Offline Sonork: 100.1679408 Thanks Meter: 51 | iphone 6plus tach important line Quote:
07-17-2018, 17:27 | #13 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | Quote:
I think you heat up too much the power IC near small glass IC. Thats why phone is dead. | |
07-18-2018, 15:37 | #14 (permalink) | |
Freak Poster Join Date: Dec 2015 Location: Canada
Member: 2498972 Status: Offline Thanks Meter: 33 | Quote:
So think back to how this started. You replaced Meson, the phone worked but two days later touch stopped again. You replaced Cumulus (why?) and then the phone died. From a touch perspective, replacing Meson and solidfying the M1 pad with a micro-jumper is the world-wide recognized solution to this issue. If you didn't do that, then you didn't do a full repair in the first place. You obviously either overheated something or caused a solder bridge or blew a part off the board. You have to start probing and inspecting to find the solution yourself so that you can learn from this. The phone is not powering on so start probing the critical power rails to see if there are any shorts. Then check the main voltage rails the PMIC produces to see if something is wrong. Check the Touch circuit. Look for partially dislodged or bridged passive components. Report back and tell us what you have tried. | |
The Following User Says Thank You to minho For This Useful Post: |
07-22-2018, 18:19 | #15 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2456421 Status: Offline Thanks Meter: 1 | Had similar problem once. One dataline is probably shorted! In my case it was U5302_RF. Check this small IC near the touch IC, reball it! |
The Following User Says Thank You to BigPunk For This Useful Post: |
