Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-13-2018, 03:08   #1 (permalink)
Member: 310423
Thanks Meter: 18
IPhone 6 Plus dead after replacing touch ic
The phone was brought to shop with touch problem, and I replace u2402 and it started working fine but the customer brought the phone in two days time saying the touch is not working again so I replaced u2401 and now the phone is dead,,,,,help,,,,,
File Type: jpg FE62043D-FEA4-4876-B227-ADD1C50C5263.jpg (80.6 KB, 135 views)
Old 07-13-2018, 05:20   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
You can measure everything arround and find it own, but you can wait - will make picture solution to our facebook page...
Old 07-13-2018, 08:20   #3 (permalink)
Member: 310423
Thanks Meter: 18
Thanks for your reply, but please try to upload it here because am not on your Facebook page.
Old 07-13-2018, 13:03   #4 (permalink)
Member: 310423
Thanks Meter: 18
Still waiting can somebody help me because the customer is on my neck
Old 07-13-2018, 15:33   #5 (permalink)
Member: 2562692
Sonork: 100.1679408
Thanks Meter: 51
Arrow iphone 6plus tach important line
try this line may be broke
Old 07-13-2018, 16:35   #6 (permalink)
Member: 310423
Thanks Meter: 18
Which line sir, can you show me the exact line that I should check. Thanks
Old 07-14-2018, 08:08   #7 (permalink)
abukuru's Avatar
Member: 2495283
Sonork: gsmvilla.com
Thanks Meter: 12
How do u mean dead.....remove both touch ic and check if phone will power on
Sent from my iPhone using Tapatalk Pro
Old 07-14-2018, 09:21   #8 (permalink)
johnaccell's Avatar
Member: 1215525
Thanks Meter: 25
replaced small touch i.c. also
Old 07-14-2018, 22:19   #9 (permalink)
Member: 310423
Thanks Meter: 18
Thanks for your reply I have done that but the phone is not powering on.
Old 07-14-2018, 22:20   #10 (permalink)
Member: 310423
Thanks Meter: 18
I changed both already
Old 07-15-2018, 07:55   #11 (permalink)
Member: 2102980
that cause overheat. cover other parts properly before replacing touch ic
Old 07-16-2018, 13:59   #12 (permalink)
Member: 2666437
Sonork: ernestoseimarfo
ok, is there anything that you can help me with
Old 07-17-2018, 17:27   #13 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
What temperature and air flow you used? I guess CHInese air station?
I think you heat up too much the power IC near small glass IC.
Thats why phone is dead.
Old 07-18-2018, 15:37   #14 (permalink)
Member: 2498972
Thanks Meter: 33
You can't realistically expect an actual "answer" here. You have an indivdualized problem and all others can do is suggest things they have seen in the past. This might work but it doesn't help you learn.
So think back to how this started. You replaced Meson, the phone worked but two days later touch stopped again. You replaced Cumulus (why?) and then the phone died.
From a touch perspective, replacing Meson and solidfying the M1 pad with a micro-jumper is the world-wide recognized solution to this issue. If you didn't do that, then you didn't do a full repair in the first place.
You obviously either overheated something or caused a solder bridge or blew a part off the board. You have to start probing and inspecting to find the solution yourself so that you can learn from this.
The phone is not powering on so start probing the critical power rails to see if there are any shorts. Then check the main voltage rails the PMIC produces to see if something is wrong.
Check the Touch circuit. Look for partially dislodged or bridged passive components.
Report back and tell us what you have tried.
The Following User Says Thank You to minho For This Useful Post:
Old 07-22-2018, 18:19   #15 (permalink)
Member: 2456421
Had similar problem once.
One dataline is probably shorted!
In my case it was U5302_RF. Check this small IC near the touch IC, reball it!
The Following User Says Thank You to BigPunk For This Useful Post:
Page generated in 0.21194 seconds with 9 queries
