04-12-2016, 23:44 | #62 (permalink) |
Freak Poster Join Date: Jan 2005 Location: iran Age: 41
Member: 103931 Status: Offline Thanks Meter: 31 | Hi Guise; I need your help for repair iPhone 6 touch screen problem after water damaged i replace touch screen and 2 chip (silver and black touch ic) same problem.. water damaged is near battery connector.also connector is checked. Thanks. |
04-22-2016, 19:05 | #67 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2550511 Status: Offline Thanks Meter: 2 | Hi did you figure this out yet? Quote:
The Following User Says Thank You to langgin19 For This Useful Post: |
04-24-2016, 23:12 | #69 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2309623 Status: Offline Thanks Meter: 0 | I have an iphone 6+ with primary mic problem. Others Cant hear very little on calls and the same happens on headphones. Only on loudspeaker can hear me. changing chargin (mic) flex, didnt work. Any solution please? |
05-09-2016, 14:17 | #71 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1168485 Status: Offline Thanks Meter: 36 | hello i have iphone 6 touch working and some times stop i change lcd the problem not solved i change ic touch the touch working but after 3 days the problem back the same touch working and stop please helppppppp |
05-17-2016, 16:01 | #72 (permalink) |
Insane Poster Join Date: Jul 2012 Location: paris, France
Member: 1780775 Status: Offline Sonork: 100.1651901 Thanks Meter: 19 | I have iphone 6 restart continuesly and suddenly it works again it restart itself ......it drops as client said ............any solution pls ..I checked all ic and parts are in good condition |
05-17-2016, 16:03 | #73 (permalink) |
Member: 1780775 Status: Offline Sonork: 100.1651901 Thanks Meter: 19 | you have to fix the ic very strongly because this ic is very weak and of course becareful on therside there are lots of ic etc etc thanks |
The Following User Says Thank You to techalam For This Useful Post: |
05-31-2016, 10:03 | #74 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42304 Status: Offline Thanks Meter: 12 | Iphone 6 dropped on water. Works perfect except silent button, and no ringer when calling on phone. In the settings ringer is working well. Only when i call on phone is not ringing, and silent button is dead. Changed the main board to a working backplate with no result. Problem is from board. Any help ? |
The Following User Says Thank You to Ciubaka For This Useful Post: |
06-01-2016, 10:25 | #75 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Hungary
Member: 2515187 Status: Offline Thanks Meter: 114 | Iphone 6 no power on, not recognize the PC. If I try turn on, current is 0.07 A. Charging current 0.5 A. I replaced U1700 and U1202, but still the problem... Any solution? |
